Old April 25, 2009, 09:49 PM
Phobia's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default GPU block
Since I got my 750i, I'd like to now buy a WC block for either a 9800GTX+ or a gtx260 core 216.
I want to keep it simple since this is going into my folding rig, and I don't want to spend much.
Old April 25, 2009, 09:52 PM
Realityshift's Avatar
Id be willing to sell my 790i but its DDR3 and has to be RMAed first =(
The Builders Hammer
Old April 25, 2009, 09:58 PM
Got a Biostar up for grabs.
http://www.hardwarecanucks.com/forum...take-look.html
Old April 25, 2009, 11:30 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Originally Posted by Phobia View Post
I want to buy a cheaper motherboard for folding.
Ideally, I'd like to use a 9800gtx+, 8800gts and 8600gts in the rig, so I'd like to have as many pci-e slots as possible.
I'm no folding expert, but doesn't mixing cards like that severely cripple overall performance.
...and wouldn't you need three PCI-E x16 slots?
Old April 26, 2009, 12:22 AM
Technically 3x PCI-E 8x would work fine as none of those cards require the bandwidth of a 16x PCI-E slot. But as far as I know mixing cards doesnt effect performance, each card processes its own WUs and generates its own PPD. Each card runs its own instance of F@H =)
The Builders Hammer
Old April 26, 2009, 06:55 AM
MAC's Avatar
MAC MAC is offline
Sounds good in theory, but I remember that it really didn't work well a little while back. Perhap F@H has been updated?
Old April 26, 2009, 07:29 AM
Dead Things's Avatar
The issue is related to number of stream processors. You can mix and match to your heart's delight as long as all the cards have the same number of stream procs. Once you start mixing cards that have different numbers of stream procs, then it starts getting a bit iffy.
For example, a 9800GTX with 128 SPs with an 8800GT with 112 SPs will result in significant performance degradation on whichever card is designated GPU1 (usually the one in slot two), while the card designated as GPU0 will fold at normal speed.
But - if you combine said 9800GTX with a 9600GT with 64 SPs, both cards will still fold at full speed because 64 is a factor of 128. The same could be said for a 32 SP 8600GT. In this case, though, the order of the cards matters, because the 128 SP card must be designated GPU0 (usually in slot one). If the card with the lower SP count is designated GPU0, then the 128 SP card will not run at full speed.
So in summary:
Mixing & matching cards with the same number of stream procs = all good.
Mixing & matching cards with different stream proc counts that cannot be factored together = all bad.
Mixing & matching cards with different stream proc counts that can be factored together = good if you can put them in the right order.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old April 29, 2009, 09:24 PM
Phobia's Avatar
bump for new stuff..
P5Q Pro Question - PCI-E slots anthonee1230 CPU's and Motherboards 11 March 16, 2009 02:30 PM
[WTB] Need S775 Board, DDR2 and two PCIE 16X slots elec999 Buy/Sell & Trade 5 March 9, 2009 09:06 AM
[WTB] AMD or INTEL motherboard with 3-4 PCI Express 16X Slots elec999 Buy/Sell & Trade 0 February 28, 2009 08:23 PM
LF: LGA775 Motherboard and PCI-E graphics card doup93 Buy/Sell & Trade 4 September 29, 2008 06:18 AM
fitting PCI components on a Motherboard tom.mullie CPU's and Motherboards 2 February 9, 2008 07:07 PM
