Old March 8, 2009, 07:05 PM
eltiti55555's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default I am a noob and i need some help :D
So about a month ago i bought a brand new computer from Best Buy, it looked pretty good for it's price. It was all going well until i decided to run L4D on it, it was slow as hell and not enjoyable at all. When i researched a little bit i realized that my Graphic card sucks, so i came here looking for a decent video card. Anyone knows for how much money could i get a "9800GT or a Ge Force 8800GTS"??
btw My Computer Spec are the following:
AMD Phenom 9550 Quad Core (2.2Ghz)
4.6GBs of RAM ( I am not sure which kind)
GeForce 9300
Old March 8, 2009, 07:10 PM
3.0charlie's Avatar
1. Do you have a spare PCI-e slot in the motherboard.
2. What is the wattage of the PSU.
3. Does the PSU have spare PCI-e (2x3 pins) connectors.
4. I'd be really surprised you have 4.6Gb of ram.
5. Welcome to the Forums.
John
Old March 8, 2009, 07:12 PM
dadzilla's Avatar
NCIX.com - Buy EVGA E-GEFORCE 9800GTX+ SC 756MHZ 512MB 2.24GHZ 256BIT DDR3 Dual DVI-I HDCP HDTV Out Video Card - 512-P3-N884-AR In Canada. -9800gtx+ for $212. I would maybe do this tho:Newegg.ca - SAPPHIRE 100259L Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards - a sapphire 4870 for $206 - pretty amazing price.
By the way, you need a lot of room: both these cards are extra long. Check the specs to see if they will fit. And your power supply needs two pci-e connectors.
I build, I game, I upgrade. I build, I game, I upgrade. I build.....
Old March 8, 2009, 07:21 PM
chrisk's Avatar
Folding Captain
You are running integrated video...builders often put a PSU in there that will run the machine 'as is', so I would really make sure of the PSU specifications before putting any video cards in there like the 9800GTX+ or the 4870 dadzilla mentioned...you can damage your computer without doing so, and void your warranty. You also need to pay special heed to 3.0 Charlie's post. If you have a decent PSU with a PCI-E connector and a PCI-E video card slot, then those are great video cards dadzilla mentioned.
Welcome to the forums!
Fold for team #54196
Old March 8, 2009, 07:24 PM
Babrbarossa's Avatar
Welcome to HWC- what would your budget be?
psst, wanna see my binder?
Old March 8, 2009, 07:40 PM
Jackquelegs's Avatar
Hello. Welcome to HWC
3.0 Charlie is right. I used to work at Futureshop as a tech, and from what I've seen those PSUs included are mostly random name branded OEM PSUs (best I've seen was a FSP 300W). Most of them are supposed to run the system that it was configured with to cut down cost (no PCI-e aux powers either). Therefore many of them are incapable of having decent aftermarket video cards.
I highly recommend you to pick up a good cheap name brand power supply like the Seasonic 400W or Sparkle 400W to run a decent card like 8800GT/9600GT
Iapetos
Zephyranthes
Old March 8, 2009, 07:41 PM
encorp's Avatar
Is there any chance you can provide a link to your computer so maybe we can answer some of the questions posted here if you are unable?
DISCLAIMER: The views and opinions expressed in the immediately preceding post are those of encorp and do not reflect the views and/or opinions of family, friends, or anyone remotely associated with encorp unless explicitly stated. encorp does not make any warranty, express or implied, or assumes any liability or responsibility for the quality, factuality or use of information in the immediately preceding post.
Old March 8, 2009, 08:20 PM
dadzilla's Avatar
Here is a link to the specs for his board: Nvidia's GeForce 9300 chipset - The Tech Report - Page 1 - btw, had I seen 3.0Charlie's post I would have refrained from giving my rather less experienced advice. We must have posted at the same time 3.0Charlie. Elitit555 would be better off to go with 3.0Charlie's advice.
JD JD is online now
I think a HD4670 would work the best in this, assuming he has a PCIe slot, since it doesn't require any additional power.
Could you post the manufacturer + model of the PC? That would help a ton.
Old March 8, 2009, 10:38 PM
Look this is my computer Computers: Desktop Computers: HP Pavilion Desktop PC featuring AMD Phenom X4 9550 QuadCore(M8530F) - Refurbished - Online Only | Best Buy Canada Web Store It probably wasn't such a good deal after lol.. ohh well...
Complete Noob Needs Help Trevor Water Cooling 10 February 21, 2009 05:18 PM
Noob question... shayan288 RAM 1 January 8, 2009 03:13 PM
Noob here, trying to get my first WC setup together. jaszypoo Water Cooling 13 December 11, 2008 06:25 PM
RAM... A Noob Question Hail Ceasar RAM 11 December 1, 2008 06:51 PM
A watercooling noob! implosion222 Case Mods, Worklog & Gallery 11 October 20, 2008 01:29 PM
