Old December 30, 2008, 03:26 PM
JD JD is offline
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default D-Link Power Adapter(s)
Basically any power adapter that comes with older D-Link routers should do I think. I've had 2 die on me already so now one of the routers I was using no longer works.
I guess they are just built pretty shoddy since they get extremely hot and apparently die out after a while of 24/7 operation.
Old December 30, 2008, 03:37 PM
norfolk's Avatar
I went to a Local distributor of electronic"s hardware and he set me up with the exact replacement Power brick.All you need is info that is usually printed on the old one.He"ll need the voltage etc,etc.I think it cost me 5$ each and over time I have replaced all 4 on mine.3 switch"s and a router.
This is my local guy here:
SAYAL Electronics - Your Source For New And Surplus Electronic Components - We Buy Your Surplus!
Old December 30, 2008, 03:46 PM
Dr_BenD_over's Avatar
Fallen Folder
Ah crap, I had one from a DI-604 sitting around for ages, looks like I might have tossed it though. I'll keep an eye out for it as I pack up to move, if it's what you need.
All's well that's Haswell
Old December 30, 2008, 06:55 PM
JD JD is offline
I'll check them out.
Hehe, I actually took one off the DI-604 (don't use it) to use on my DGL-4300 since that one died too. The one on my DI-624 crapped out around Christmas time.
NIC Link speed not gigabit? 3.0charlie Networking 18 November 27, 2008 06:15 AM
Do you link your FSB:RAM? What's your ratio? chouchou Overclocking, Tweaking and Benchmarking 6 November 16, 2008 09:34 PM
D-Link DGL-4500. Scotch Tape Networking 1 January 24, 2008 08:36 PM
Why doesn't DC link to NCIX support? qwerty Suggestions & Feedback 1 December 10, 2007 03:42 PM
Problem with pci-e link width Uplasenko Troubleshooting 9 April 9, 2007 05:42 PM
