Old November 25, 2008, 03:07 PM
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default 240mm Rad,1/2 inch fittings g1/4t,nb,sb block
i need this gear asap anyone have any water gear laying around
CPU: Dual QX9775
MOBO:D5400xs
Ram: 4GB FB-Dimm
PSU:Koolance 1300 Watt
Graphics: Tri sli XXX GTX280 XXX
HDD:2 Supertalent SSD
LCD:24IN Samsung wide
CASE:TT Armor
Danger Den WC Setup
4 Pelts 226Watt
Old November 25, 2008, 06:21 PM
Lima's Avatar
Does it absolutely need to be a 240mm? If not, I got a Feser TFC Xchanger - Triple Radiator 360 that I will not be using.
Old November 26, 2008, 02:39 PM
check youre PM
