Old November 22, 2008, 05:51 PM
elninio's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
Default half inch barbs
i need half inch barbs like the one on the d-tek V1 - i need two for a BIX360 radiator
Old November 23, 2008, 11:51 AM
you might want to pm A4g and work something out
http://www.hardwarecanucks.com/forum/buy-sell-trade/11326-apollos-fs-ft-lf-thread.html
Intel Core 2 Duo e8400 @ 3.8GHz
Mushkin Ascent 1x2gb
Asus P5N-D
BFG Geforce 8800GT OC SLI (folding issues...)
WD 500GB
NZXT Apollo
OCZ Vendetta 2 w/ Bolt-thru kit +Scythe S-Flex F
Syncmaster T220, Razer Deathadder, Lycosa Mirror Edition, X-240 speakers
Old November 23, 2008, 12:21 PM
elninio's Avatar
Sorry, the page you have requested cannot be found.
he has PMed me. but the problem is that hes in montreal and the shipping may come to cost more than the barbs themselves!
Old November 24, 2008, 10:01 AM
ebdoradz's Avatar
i think i have a pair of 1/2 barbs the Dtek one.
Let me check when i get home
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old November 26, 2008, 12:03 PM
elninio's Avatar
Thanks -- but I need in toronto! If your going to ship from far away - can you put it in an envelopped and pay standars shipping as a regular letter?
Old November 26, 2008, 12:07 PM
ebdoradz's Avatar
gonna check what i can do with the shipping
Old November 26, 2008, 12:25 PM
MpG's Avatar
MpG MpG is offline
I'm sure I've got some extras kicking around that I could send down the street. I'll check when I get home this afternoon. Do you know for a fact that the same barbs that go into your Fuzion also thread properly into the radiator? IIRC, by default, the older BIX series came with built-in 1/2" barbs, with the generic threading being optional.
Old November 26, 2008, 12:30 PM
elninio's Avatar
i'll check right now
Old November 26, 2008, 02:32 PM
elninio's Avatar
ah i've got some - I went looking for some teflon tape and stumbled upon a store called 'Jacod's' , its on queen street and spadina - they have 1/2 inch barbs with 3/8 threads like the D-tek barbs
Old November 26, 2008, 02:44 PM
MpG's Avatar
MpG MpG is offline
Have you tried the in the rad? The Fusion uses a G1/4 threading, which is more or less NPT 1/4" where water-cooling is concerned. If not, I've got some spare G1/4 barbs, and I'm pretty sure they wouldn't put a regular letter envelope over the the weight limit. Let me know.
Edit: What are you using teflon tape for? If the barbs have o-rings, don't bother with the teflon tape.
