  #21 (permalink)
Old October 17, 2008, 04:53 PM
Gunner86's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
So no takers on that water cooling kit? It's an awesome deal
  #22 (permalink)
Old October 18, 2008, 10:33 AM
Gunner86's Avatar
Bump
  #23 (permalink)
Old October 18, 2008, 11:34 AM
Does this come with the MCP655?
  #24 (permalink)
Old October 18, 2008, 11:36 AM
Gunner86's Avatar
Yes it comes with everything you will need except tubing.
Kit specs:
APOGEE Water Block Specifications:
  • Compatibility:
    • Intel:
      • Socket 478
      • Pentium 4
      • Socket 775
      • Pentium 4 Prescott
      • Socket 603/604
      • Xeon 400, 533, 800 FSB, Nocona 800Mhz FSB
    • AMD:
      • Socket 462 (Requires motherboards with 4 mounting holes around socket)
      • Socket A (Requires motherboards with 4 mounting holes around socket)
      • Athlon
      • Duron
      • Athlon MP
      • Athlon XP
      • Socket 754
      • Socket 939
      • Socket 940
      • Athlon 64 bit processors
      • Sempron
      • Opteron
      • X2
      • AM2
  • Nylon Fittings: 7/16" ID (5/8" OD)
  • Fitting O-ring: (2) EPDM O-ring AS568A Dash Number 112
  • Base plate dimensions: 2" x 2" (50.5 x 50.5 mm)
  • Assembly weight: 6.7 oz (190 g)
MCW60 VGA Water Block Specifications:
  • Model: MCW60-B
  • Material: Acetyl Copolymer water block housing, CNC machined copper base
  • Compatibility: ATI Radeon and nVIDIA GeForce
  • SLI-Compatible: Yes
  • Crossfire-Compatible: Yes
MC14 BGA Ram Sinks Specifications:
  • Dimensions: 14mm x 14mm x 14.5mm (L x W x H)
  • Material: Forged C110 Copper
  • C/W: 9.0 (including TIM joint)
  • Max Load: 5W per heat sink
  • Weight: 8.5 grams
MCW30 Chipset Water Block Features:
  • High flow and thermal performance for all system configurations
  • Completely unrestricted chamber to minimize pressure drop
  • Hooks directly to Intel platform chispets without removing the motherboard with a safe hook/spring assembly
  • Thru-motherboard installation for AMD platform chipsets with slotted brackets for compatibility from 2.08" (53mm) to 2.36" (60mm) center to center distance between mounting holes
  • Compatible with all current Asus SLI motherboards
  • Retention mechanisms included for both Intel & AMD platforms
MCP655 Industrial Pump Specifications:
  • Nominal Voltage: 12VDC
  • Operating Voltage: 6~14VDC
  • Nominal Power: 24W
  • Nominal Current: 2A
  • Motor Type: Brushless, Microprocessor Controller
  • Maximum Head: 10ft
  • Maximum Discharge: 317 GPH (1200LPH)
  • Maximum Pressure: 50PSI (3.5 BAR)
  • Temperature Range: 32F to 140F (0C to 60C)
  • Electrical Connector: Molex 4-pin
  • Weight: 1.4 LB (650gr)
  • Impeller Housing Material: Noryl
MCRES-Micro Reservoir Specifications:
  • Material: Clear Acrylic Laser-Cut Panel
  • Maximum Capacity: 4.5oz, 133cc
  • Barbs: 7/16" ID (5/8" OD)
  • Mounting: Screws or Fastening Tape Pads Consisting of a Strip of Nylon with a Surface of Minute Hooks that Fasten to a Corresponding Strip with a Surface of Uncut Pile
  #25 (permalink)
Old October 18, 2008, 06:56 PM
Gunner86's Avatar
One last bump for today
  #26 (permalink)
Old October 18, 2008, 10:02 PM
Gunner86's Avatar
Everything is sold!!
  #27 (permalink)
Old October 18, 2008, 10:54 PM
Nice dude Congrats
