Old October 5, 2008, 06:03 AM
matsta31's Avatar
Recent iTrader Ratings
Positive Positive 0 0 0
Neutral Neutral 0 0 0
Negative Negative 0 0 0
I dont remember having any screw with the rad, but I will gladly include the 2 Barbs you see in the pictures.
Sold hardware again.....
Currently using WHS hardware....
Old October 5, 2008, 02:34 PM
matsta31's Avatar
Old October 5, 2008, 02:52 PM
Apollo4g's Avatar
I can vouch for matsta31 all!
Dealt with him locally before, great guy, trustworthy!
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old October 5, 2008, 03:10 PM
Yeah I've seen lots of good comments on him, I'm looking to get that triple rad, but there are usually various screws that come with rads. Especially to mount them on the case itself...
Did you buy screws to mount the fans yourself ?
Old October 5, 2008, 05:17 PM
3.0charlie's Avatar
I never had any screws come with any of my rads... always had to buy the correct thread pitch and length.
Hydro-Quebec is salivating...
Old October 5, 2008, 05:31 PM
matsta31's Avatar
I also bought them, Petra did not ship any screws. I took it to the hardware store, and found a machined screws that worked. I think they where 6/32 or 8/32 diameter and 1 inch 1 1/4 inch lenght.
NCIx even sells them aside, Linus went to the hardware store to find one, then they make you a lilte package....
Old October 5, 2008, 05:34 PM
Velociraptor is mine :)
heatware
Old October 5, 2008, 05:52 PM
Gr8 thanks masta, I'll contact Linus on those, I know the ones for fan mounting, more concerned about screws to mount to case.
Currently I am looking for more of a trade, my 2 dual rads for a triple, but I might buy that triple rad.. Thanks.
  #19 (permalink)
Old October 5, 2008, 06:45 PM
matsta31's Avatar
V-Raptor sold. Keep the PM coming !
  #20 (permalink)
Old October 5, 2008, 07:17 PM
I had a pack of screws come with my Black Ice rad, and as far as I know, I've seen other people get packs of screws with their rads, so it might be NCIX that takes them out.
