I don't trust AVG either. Avast or BitDefender are great free ones that seem to do much better.
__________________ CSE: Lian-Li PC-A70 MOB: Biostar T-Power I45 CPU: Intel C2D E8600 @ 4.3ghz RAM: 4gb g.skill pc2-8000 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC Power & Cooling 750w Heatware: My Heatware |
I'd have to agree with BrainEater, Save what you need to save, and blow out windows with a fresh install. This could end up being a loosing battle if its been going on for even a week. Fresh Install of the OS is going to save you a hell of a lot of time, and maybe wasted effort.
__________________ My Rig: E8400 4.0GHZ (3.0ghz) | Asus P5Q-E | Xigmatek HDT-S1283 HSF | EVGA GTX 280 | 2x Mushkin Ascent PC2-8000 Dual Channel 4Gb 2x 320gb WD HDD 7200rpm - 1x 160gb WD HDD 7200RPM | Coolermaster 650W PSU | Silverstone FT01 CSE | Samsung SyncMaster 216bw ---------------- My Silverstone Fortress Mod --------------- Upcoming Changes/Upgrades: ------------------ Heatware: mattlef Positive: 3 Negative: 0 Neutral: 0 Click Here Click Here For Ebay ------------------- |
Here's something which might be of interests also: anti-virus on Wikipedia.
I don't like AVG either. A few years ago there was an infection on this computer that caused some pop ups and other "minor" problems. AVG never found what it was. I installed Kaspersky trial and it was gone immediatly. Then I switched to AVS(Aol sponsoring Kaspersky) and it was amazing. After the license was over I went back to AVG on my father's computer, but in the meantime, I was trying Avira and Avast on mine. Back to the situation now. I finally managed to update AVG and restarted scanning, I went to scan directly into the windows folder as it was the one that was affected and surprise(not really) I found some different virus: Trojan horse downloader.Small.DGT Trojan horse SHeur.CDSC Trojan horse Agent.AADO The scan is not over, but I am at 56 after 30minutes and not a trace of the trojan r.g yet. Edit: I noticed that as soon as I touch the keyboard the computer freezes Edit 2: I don't know if that means anything to anyone, but when I go into graphic properties(where we can change the background), I only have 3 tabs parameters, appearance and theme. It wasn't like that before. Edit 3: after I last touched the keyboard, I had to restart... Once that is done, I get just past the starting windows screen and then the screen stays blue, nothing more happens, I can move the mouse, but can't press any keys on the keyboard. In safe mode, the screen is black but the problem is the same(including the freeze as soon as a key is pressed).
__________________ 5½ years old rig ? P4 1.7Ghz MSI MS-6547E 768mb RAM ATI Radeon 7200 40Gb Seagate HDD w/ Xp 7Gb Maxtor HDD w/ Linux TigerPlus 300 Watt PSU (never heard of such company) Broken LG CD-rom drive that seems to work sometimes Last edited by Kilauea; August 21, 2008 at 11:28 AM. |
It's quite possible that, during the system disinfection, a system file may have been corrupted or deleted by AVG which is adversely affecting your bootup. I responded to your other thread about accessing the recovery partition but, should you not wish to take that route, you may still be able to boot into Safe Mode w/ Command Prompt and run chkdsk /r (checks for and attempts to repair file system errors) and/or fixboot (attempts to fix the Master Boot Record). Personally, I'd recommend just doing a system recovery and next time you should make your recovery discs (it prompts you when you first boot it up and will keep annoying you until you make them, unless you tell it not to). |
eeek. A quick lookup on the SHeur trojan yields some info. It disables your firewall and kills your internet. It also installs a full blown rootkit. You have some serious issues now.You should consider every password on that machine compromised.As well , any personal info/banking/whatever , has probably been compromised as well.. You need to immediately talk to your dad and find out what kinda personal info was on there , and change it all. Sorry bud , but it's time to stop trying to clean , and seriously consider reinstalling windows.
__________________ Intel Q9450 /Asus Maximus Formula/Mushkin 6400 /bfg 8800gtx/WD raptors/etc... |
| Quote:
You got the BRAVIAX ? ThaT's a nasty MF :) AVG skips on a lot - I use Spyware Doctor (that one effectively removes BRAVIAX and any strays left overs) don't attempt to manually remove them, some will show up again. Get yourself spyware doctor, you will be surprised how much stuff it finds on your system. You should have a BRAVIAX files in the %windows%system32 directory too. I use AVIRA security suite, that one also finds stuff, has an excellent detection rate, and it removes more stuff left than other programs. I had the BRAVIAX too and neither Spybot S&D 1.6 nor AdAware 2008 even detected it ! Same for Norton, it skipped on a lot of that too. |
| Quote:
My mom uses Opera to pay bills, but it is safe to assume that she did not do it for 14 days or more. Besides that, he has his email that is access through Outlook, it recorded his password so he doesn't need to enter it everytime(either way he doesn't know it). I believe that is all that is done on his computer that is sensitive. So, which of these should I worry about ? And while we are at it, I plan to get myself an HDD enclosure along with an HDD, but before doing anything, I guess I will plug my father's HDD into the thing because he has a sata drive and I am still with IDE, and then save the information on my HDD and my ipod. Then I'd do whatever with the compaq disk that came with the computer. Would this work ? or would I be at risk of having a virus on my own computer if I were to do that ?
__________________ 5½ years old rig ? P4 1.7Ghz MSI MS-6547E 768mb RAM ATI Radeon 7200 40Gb Seagate HDD w/ Xp 7Gb Maxtor HDD w/ Linux TigerPlus 300 Watt PSU (never heard of such company) Broken LG CD-rom drive that seems to work sometimes |
| Thread Tools | |
| Display Modes | |
