Go Back   Hardware Canucks > SOFTWARE > General
Old December 19, 2006, 08:12 PM
Babrbarossa's Avatar
Super Moderator
Default Vista antivirus
I am trying to broaden my horizons as I shop for antivirus for my new computer but I've never tried anything other than symantec, so I'm wondering what's out there that's particularly good value, and geared for vista?
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old December 19, 2006, 10:11 PM
Level up: 7% Level up: 7% Level up: 7%
Level: 23 - 1,384 points to level up
Avast and its free!
Old January 6, 2008, 10:10 AM
Level up: 53% Level up: 53% Level up: 53%
Level: 7 - 66 points to level up
Talking
AVG using it on vista ultimate now It is GREAT!
AVAST is a second choice(for me) ran it too previous (have the two tray icons run merged.)
These Av's are one of the few "if its free that all its worth reasonings" thats simply NOT true!!!
Cambridge,ON
A8N-SL1 Premium
AMD-Opteron 180 S939 X2 Toledo-"Denmark" @2.64Ghz.
OCZ dual channel platinum 2gb.
BFG 8800 GTS OC
4 wd satas/Samsung 2053BW
Antec P180b/4 120mm tricools
Seasonic S12 650
Vista Ultimate/XP professional
32bit
Old January 6, 2008, 10:26 AM
3.0charlie's Avatar
I second AVG. Been using it for many years, never let me down. Updates once daily.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old January 6, 2008, 10:52 AM
Thumbs up
Its done "its thing" here to for safety a couple times
Cambridge,ON
A8N-SL1 Premium
BFG 8800 GTS OC
Seasonic S12 650
32bit
Old January 6, 2008, 11:51 AM
Prof. Dr. Silver's Avatar
Hardware Canucks Reviewer
AVG ROCKS! Symantec....not so much! I found that Symantec was a huge system hog!
Ps. And it's free...why would you spend your money?
Old January 6, 2008, 01:01 PM
Talking
Symantec the traditional say norton 2007 av etcetera can really be picky about say certain Windoze features you don't have set the "way they deem them to be"
Cambridge,ON
A8N-SL1 Premium
BFG 8800 GTS OC
Seasonic S12 650
32bit
Old January 6, 2008, 01:25 PM
Level up: 56% Level up: 56% Level up: 56%
Level: 7 - 62 points to level up
I have read and heard that NOD32 is currently the best anti virus out there. Unfortunately i don't know from experience. I use Norton myself.
Old January 6, 2008, 01:55 PM
Norton is crap whether its the Symantec or not.
Bitdefender, NOD32, Avast are all good.
One isn't better than another as you sometimes need 2 or 3 to clean pesky antiviruses.
CSE: Lian-Li PC-A70
MOB: Biostar T-Power I45
CPU: Intel C2D E8600 @ 4.3ghz
RAM: 4gb g.skill pc2-8000
GPU: XFX 8800 GT Alpha Dog Edition
PSU: PC Power & Cooling 750w
Heatware: My Heatware
Old January 6, 2008, 02:26 PM
Level up: 34% Level up: 34% Level up: 34%
Level: 12 - 268 points to level up
I wouldn't run anything other than Kaspersky or NOD32 ... AVG free is sufficient for most people, but definitely doesn't compare to the top tier AVs ...
Of course, the most important thing to keep your computer virus free is how you use it ...
Best Free Antivirus Bundle? Infiniti General 16 August 8, 2008 04:36 PM
Microsoft OneCare Last in Antivirus Tests Babrbarossa Reviews & Articles from the Web 3 March 4, 2007 05:42 PM
