Go Back   Hardware Canucks > SOFTWARE > General
  #21 (permalink)
Old February 9, 2008, 02:20 PM
Symantec AV's actually tends to have a very low false-positive rate, and Symantec Corporate is quite fast, none of the bloated GUI or non-AV features of Norton.
  #22 (permalink)
Old February 9, 2008, 02:42 PM
Level up: 98% Level up: 98% Level up: 98%
Level: 7 - 3 points to level up
Guess I should put in a vote for AVG, I haven't had any problems, but like so many others say, you have to be careful where you go, my kids are getting older now and are starting to use the internet - stupid webkins...- for school and playing a little, but I'm pretty picky about what is accepatable. no problems with AVG yet...that I know of. ;)
  #23 (permalink)
Old February 9, 2008, 05:19 PM
low351's Avatar
Level up: 8% Level up: 8% Level up: 8%
Level: 10 - 260 points to level up
When budget is a problem I recommend Avast, merge the icons and it's unobtrusive.
If you can afford to spend a few beans then bitdefender is a better solution because it incorporates spyware scanning as well.
You can find it for around $30 for 2 year subscription or multiple PC install.
  #24 (permalink)
Old February 9, 2008, 06:21 PM
vdf22's Avatar
Level up: 22% Level up: 22% Level up: 22%
Level: 9 - 183 points to level up
That's true. If you're careful what sites you visit, you may never get a virus. I recommend AVG.
  #25 (permalink)
Old February 9, 2008, 09:06 PM
Babrbarossa's Avatar
Super Moderator
I've been using Kaspersky lately and I like the three licenses for 30 bucks for the whole suite- sometimes you can get it for even less. Looking at my running processes, it seems to take up very little resources although I haven't added it up yet.
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
  #26 (permalink)
Old February 20, 2008, 11:27 PM
Level up: 86% Level up: 86% Level up: 86%
Level: 9 - 34 points to level up
AVG is common, but it's not that great for detection rates.
If you want a good free one, i believe the best is BitDefender.
  #27 (permalink)
Old February 20, 2008, 11:41 PM
Thund3rball's Avatar
Level up: 51% Level up: 51% Level up: 51%
Level: 14 - 285 points to level up
Originally Posted by zlojack View Post
I don't use anything... I'm just very careful about where I go and what I open.
I do a free online scan every once in a while.
I did this for a couple years too. Never had a problem. Funny when I actually had Norton 2001 (IIRC) I got a virus and it was a nasty bugger to eliminate. I gave up on Norton around 2005 when they made me buy a full new suite instead of a cheap subscription fee, and then it proceeded to deactivate itself on a daily basis based on the fact that it thought it had not been activated :(
Been using Kaspersky for about a year now and I really like it. Very light footprint on XP and excellent options to get running the way you want it to. Not sure if it's been fixed or not but Kaspersky was very Vista unfriendly... but is probably fixed by now? NOD32 would be my 2nd choice if Kaspersky still does not play nice with Vista. Guess I'll find out soon when my new laptop arrives
Desktop
AMD 5000+ BE @ 3.2GHz \\
Tuniq Tower 120 \\ Gigabyte GA-MA770-DS3 \\ Mushkin 2x1GB HP2-6400 \\ Corsair HX520 \\ Evga 8800GT SC w\Zalman VF900 \\ Seagate 3x250 7.2K \\ Dell 2007WFP \\ Razer Deathadder \\ XP
Laptop
Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ Vista Ult. (RED)
  #28 (permalink)
Old February 21, 2008, 03:06 AM
Level up: 34% Level up: 34% Level up: 34%
Level: 12 - 268 points to level up
Kaspersky works fine on all my Vista and XP machines ... I've also installed Kaspersky on dozens and dozens of computers sold through work and we receive very few complaints about it. The few complaints that we have received were easily fixed (somehow Internet Explorer 7 made it onto Kaspersky's blocked list) ...
To this day, I have yet to see an infected computer come in that's running Kaspersky, which is an excellent sign.
  #29 (permalink)
Old February 21, 2008, 06:48 AM
zlojack's Avatar
Level up: 1% Level up: 1% Level up: 1%
Level: 16 - 714 points to level up
I had Kaspersky and it was fine, but when the free trial expired I just uninstalled it.
Does Bitdefender have a 64-bit version?
MM H2GO ~ GA-X58-UD5 ~ i7 920
4GB OCZ Gold Edition DDR3-1600GHz ~
~ Soundblaster Fatal1ty XtremeGamer Pro ~ Samsung SyncMaster 245b 24"
2 WD Raptor 150 GB (RAID0)/ WD Caviar 500 GB ~ Samsung DVD/RW ~ Vista Ultimate 64
  #30 (permalink)
Old February 21, 2008, 07:26 AM
Good news for me. BTW I think the way IE ends up on the blocked list for some people is after some Windows updates, Kaspersky sees that IE has changed and a message pops up notifying you of a "suspicious" action when you go to launch IE because it has changed. If you choose to deny/block it than voila... IE is now the enemy. LOL
Desktop
Laptop
Best Free Antivirus Bundle? Infiniti General 16 August 8, 2008 04:36 PM
Microsoft OneCare Last in Antivirus Tests Babrbarossa Reviews & Articles from the Web 3 March 4, 2007 05:42 PM
