Old August 25, 2008, 05:28 PM
BALISTX's Avatar
Default HSF for a Quad Core in HTPC case
What would be a good non-expensive cooler for a Quad Core CPU in a HTPC case? Particular this case.
Nmedia HTPC-1000B Desktop Media Centre Case mATX Black 1X5.25 4X3.5INT Card Reader No PS - DirectCanada
Old August 25, 2008, 05:37 PM
Cptn Vortex's Avatar
NCIX.com - Buy Arctic Cooling Freezer 7 LP Low Profile HTPC Dual Heatpipe Heatsink LGA775 28CFM W/ 80MM Fan - FREEZER-7-LP In Canada.
Maybe..... not sure how good though.
NCIX.com - Buy Scythe Shuriken 3 Heatpipe Low Profile HTPC CPU Heatsink AM2 LGA775 S478 S754 S939 S940 W/ 100MM Fan - SCSK-1000 In Canada. This looks ok.
NCIX.com - Buy Silverstone Nitrogon NT06-LITE LGA775 S478 S939 AM2 Copper Base Heatpipe Heatsink *No Fan* - NT06-Lite In Canada. Seen this in some smaller cases, need to measure height.
NCIX.com - Buy Thermalright SI-128 SE LGA775/AM2 Heatpipe Cooler Heatsink *Fan Not Included* - SI-128-SE In Canada. Same with this. If the height is fine, it would be the best choice.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Old August 25, 2008, 05:42 PM
SI-128 is a great HSF for htpc cases if it fits.
