Old August 24, 2008, 05:13 AM
SmogTown's Avatar
Default CPU Cooling Question
On my new build I'm planning on using the OCZ Vendetta 2 to cool my cpu. However I want to use a different, non PWM fan on it since I'm going to have a fan controller on this build. Will the system notice the lack of a cpu fan? And if so will this cause any faults. Its my first time going this route.
Old August 24, 2008, 05:32 AM
sswilson's Avatar
In the good old days, motherboards would shut down if there wasn't a signal from a cpu fan. It's been quite a while since I ran a board which had that problem.
It would help though if you could list your motherboard so that one of our members who's running WC on one could verify for sure. (nothing like getting info direct from the horses mouth.... :) ).
If you're going to be asking a lot of hardware questions, it would be helpful if you could make up a sig with your intended build. That way the info will be available in every post you make.
Welcome to the forums BTW!!!! :)
Old August 24, 2008, 05:41 AM
JD JD is offline
You will surely get an error during post saying "CPU FAN FAILED" or something to that effect. If you go into the BIOS > Hardware Monitoring page, you should be able to set it to "Ignore" or similar.
Old August 24, 2008, 06:37 AM
SmogTown's Avatar
Thank you for the help and the welcome . This forum has loads of information.
Intel Q9550
OCZ Vendetta 2
Asus Maximus II Formula
Evga GTX 285
4GB Mushkin DDR2 1066Mhz
2 Seagate Barracuda 7200.11 640GB
Corsair TX750
Coolermaster HAF 932
Old August 24, 2008, 09:54 AM
"Quote This..."
Have you got your fan controller yet? My Zalman MFC1 has separate fan rpm leads you run to your mobo.
Old August 24, 2008, 12:32 PM
SmogTown's Avatar
Yes I already have the sunbeam rheobus.
Intel Q9550
OCZ Vendetta 2
Evga GTX 285
Corsair TX750
Old August 24, 2008, 12:36 PM
"Quote This..."
hmmm, the sunbean rheobus product page states it has 2 rpm signal wires.
Contents:
  • Main Panel x 1
  • Power Wire x 1
  • RPM Signal Wire for M/B x 2
  • 3 pin to 3 pin Wire x 2
  • 3 pin to 4 pin Wire x 2
  • User's Guide
Old August 24, 2008, 12:37 PM
Just plug the fans into the rheobus and boot your computer.
If it comes up with the CPU fan error just go into the bios and disable it.
Personally I've never used the CPU fan header once I've switched to a aftermarket HSF as I found the AUX/SYS fan headers have better control for fans.
My Abit board allows me to change fan speed using voltage.
Old August 24, 2008, 12:39 PM
SmogTown's Avatar
Should've read that more closely.
Intel Q9550
OCZ Vendetta 2
Evga GTX 285
Corsair TX750
Old August 24, 2008, 12:40 PM
no prob
