Old August 12, 2008, 06:03 PM
Jon_di2's Avatar
Default Suggestions for a CPU heatsink?
Okay so I built my rig with the stock CPU heatsink
So the temps are a little high... which I don't appreciate
So here I am looking for suggestions on a cpu heatsink, keep in mind I know nothing about heatsinks (I know what they do, just not which one to get)
Also, I would need to buy thermal paste right? (which brand?)
Finally if the heatsink you suggest needs a fan, let me know which one.
Thanks!
See my sig for any info regarding my rig.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old August 12, 2008, 06:16 PM
CTA's Avatar
CTA CTA is offline
thermalright true black or ocz vennta 2?
use noctua p12 fan if you prefer preformance ratio nosie...
heck you dont read HWC articles/reviews...
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old August 12, 2008, 06:28 PM
Jon_di2's Avatar
I did read stuff but I don't like mentioning anything to influence how people respond. But since you have to ask, Is the Triple Heatpipe one better?
NCIX.com - Buy OCZ Vendetta 2 Triple Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 120MM Fan 800-1500RPM 20-32DBA - OCZTVEND2 In Canada.
Pricematch with directcanada for only 29.90
Or should I get this one
NCIX.com - Buy OCZ Vendetta Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 92MM 1200-2800RPM - OCZTVEND In Canada.
Only 20...
Oh and it looks to already have a fan right?
I also heard the Ultra 120 was good, but it's a fair bit more expensive...
Old August 12, 2008, 06:44 PM
I'm going to be dropping my True 120 for a Vendetta 2 this friday.
Old August 12, 2008, 07:22 PM
CTA's Avatar
CTA CTA is offline
yes of course triple heatpipe ( according to this OCZ Vendetta 2 CPU Cooler Review )
yes true black is totally 110 cdn if you buy two p12 fans... i believe vendetta 2 ( sorry i misspelled it before) is best value cpu cooler... but fan little loud than p12.... if you replace fan with p12 then you will get best result of temperature as almost same as true black...)
Old August 13, 2008, 04:18 PM
Retro's Avatar
You may also want to consider the Noctua NH-U12P heatsink. See the excellent review by AkG. It comes with an NF-P12 fan and clips for a second fan as well. I replaced my former TRUE with one and the performance is comparable, but the base and mounting system of the Noctua is far superior to the Thermalright. NCIX has them in stock.
Latest build:
i5 750@3800MHz 20x190@1.38125v
Noctua NH-U12P/NF-P12
4G GSkill DDR3 2000 Ripjaws
Asus P7P55D-Pro
2x EVGA GTX275 in SLI
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
Old August 13, 2008, 05:07 PM
misterlarry's Avatar
I like my True 120, but actually adding the Accelero (passive) to my GPU dropped all my temps by about 8 degrees. I'm hoping Arctic Cooling comes out with an Accelero for the 4870x2 before I decide to go there.
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old August 13, 2008, 06:38 PM
..'Ant'..'s Avatar
Get the Xigmatek HDT-S1283 with Arctic Silver 5 Thermal Paste.
Old August 13, 2008, 09:53 PM
Jon_di2's Avatar
Ok so I went with the OCZ Vendetta 2, and the Noctua p12 Fan (it was on sale, why not), and the Arctic Silver 5 Thermal Paste.
I looked at The Xigmatek HDT-S1283, which was almost the same as the OCZ Vendetta 2 and cheaper, but since it was only $5 cheaper I just went with the Vendetta 2.
I checked this out too.
http://benchmarkreviews.com/index.ph...1&limitstart=8
Thanks for everyones help!
Old August 14, 2008, 12:36 AM
Well to say the least, Xigmatek was the original version of the 3 direct touch heatpipe cooler, and then Vendetta 2 came out, which was very slight changes to the original design (Xigmatek), and it performed better surprisingly. But you gotta see this review HDT Cooler Shootout! - Icrontic.com.. The new king is Sunbeam Core Contact Freezer, it beats the TRUE 120 as well. In my opinion get it, its worth it.
