Old August 10, 2008, 09:04 AM
cyberspyder's Avatar
Default Petra has SAN ACES IN STOCK!
Petra's Tech Shop
Stock is limited...HURRY UP!
Old August 10, 2008, 09:37 AM
Babrbarossa's Avatar
6 watts- I think that's the max my mobo headers can handle- there must be quite a few that can't take that much. I would definitely run them from the PSU.
Old August 10, 2008, 09:44 AM
Supergrover's Avatar
Originally Posted by Babrbarossa View Post
6 watts- I think that's the max my mobo headers can handle- there must be quite a few that can take that. I would definitely run them from the PSU.
IDK I never use the mobo's headers always run my fans off of a fan controler have for years since the tornado/AXP days.
R.I.P.
Old August 10, 2008, 09:57 AM
You don't run them from the motherboard
They need a fan controller.
Old August 10, 2008, 10:10 AM
MpG's Avatar
MpG MpG is offline
Damn, that's tempting. I'm sure my fan drawer has room for a few more fans... Unfortunately, they're way out of my rpm range, even when undervolted.
Old August 10, 2008, 10:27 AM
You can run them from the motherboard- see the connector in the pic- What I was saying is that one shouldn't do it.
Old August 10, 2008, 10:36 AM
Read their disclaimer.
Connector: 3pin w/ rpm monitoring
We strongly suggest you refer to your motherboard manual to make sure your Case Fan Headers can handle this fan before plugging it into your motherboard.
A motherboard should not be used and a fan controller should.
Current: .52 Amp
Power: 6.24 W
Wanna fry your board?
Old August 10, 2008, 10:37 AM
Mr. Cipher's Avatar
Why are these special?
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Old August 10, 2008, 10:46 AM
When they are undervolted to 7v they are the BEST performing 120x38mm on the market.
Quiet and lots of air movement.
Old August 10, 2008, 10:53 AM
MpG's Avatar
MpG MpG is offline
Depends on your board. The manual for my Maximus claims that each header is good for up to 12W, or 40W combined. Although I think I'd have to have a pretty good reason before I tried pulling 12W off a fan header, but for 6W, I wouldn't hesitate.
