Old August 5, 2008, 07:46 PM
belgolas's Avatar
Well here is what I would do if you really want that board. Buy the board and the black TRUE and try it. If it does not work return the TRUE to NCIX for an exchange. They will do it for free with the advance RMA for 3% extra. The worst that will happen is you will have to what a day or 2.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old August 6, 2008, 01:06 AM
Ok thank you all ,for giving me clear and exact answers.Additionally I am a fan of CPU air cooling(i think it works better than watercooling) and i will probably watercool the rest components.Anyway i have asked a thermalright's guy and told me, to install the heatsink using the stock backplate ,Vertically and also sugested me to use zip ties.
Mike
Old August 6, 2008, 04:43 AM
Mibs's Avatar
Mike
I'm sorry but why do you think air cooling works better? I think there is enough evidence around here to disprove that opinion. As for the TRUE, it should fit one way or another.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old August 6, 2008, 05:50 AM
cyberspyder's Avatar
Give it up...he doesn't want anyone disproving him.....
Old August 6, 2008, 02:55 PM
Default Reply
As I mentioned earlier...
I may use my earlier posting as a quote.
