<~----> anyone heard of this cpu cooler? - Hardware Canucks
Old August 3, 2008, 11:48 PM
CTA's Avatar
CTA CTA is offline
Default anyone heard of this cpu cooler?
Tuniq - Tower 120 Cooler
it looks greatly improving over Ultra 120 extreme (non true black)
hard to believe?
i mean look at this result (this is best result that i can show for now...)
little different than what the site displays...
it cost 46.xx cdn at ncix... i think its very good value compare to U120 extreme
so do you agree... or disagree?
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old August 4, 2008, 12:06 AM
hard to believe?
Tuniq is crap compared to the 120.
I had the tuniq and turfed it.
Old August 4, 2008, 12:39 AM
CTA's Avatar
CTA CTA is offline
really? bad quality?
and i forget to add the link Techgage - CPU Cooler Roundup - 22 Models Tackle Our QX6850 at first post
sorry!
Old August 4, 2008, 12:46 AM
sorry!
Big, bulky and inefficient.
Old August 4, 2008, 05:51 AM
burebista's Avatar
IMO it's a very good cooler.
Old August 4, 2008, 09:09 AM
cyberspyder's Avatar
But gets overshadows by the newer coolers...it was good a couple years back but the TRUE took it's turf. Not worth it now.
Old August 4, 2008, 09:57 AM
burebista's Avatar
Agree, but only if you are a hardcore OC-er and those 3-4-5°C in full-load matter.
But if you are a casual clocker and you want to keep some money in pocket then Tuniq is (still) a great option.
Old August 4, 2008, 10:08 AM
Mibs's Avatar
Agreed, while not the best it's still a good option. I've seen many people with it in their rigs. It was one of my main choices when I built my current rig. I ended up going with the TRUE though.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old August 4, 2008, 12:21 PM
Default Reply
Yeah, I agree with most of you. The Tuniq is a great cooler but it just can't stack up to the newer and better coolers now. Just a few months ago, it was considered the 2nd best cooler out there behind the TRUE. But then came along the innovation of H.D.T...
