  #21 (permalink)
Old November 12, 2009, 01:58 AM
Sorry for lack of updates but I got made redundant from work, had the 2 HDD's fail (I bloody neglected their cooling during the "open case" build) and then had the cheap and nasty lugs on the stock Intel HS pop and kill my gem 805D in the missus PC .
Well my Video Card was hitting concerning temps ranges and it is approaching summer down here so I decided to try and address this issue with initial results of 12C lower at idle and 14C lower at load. All can be seen here:
Modding the 4850 stcok cooler and reducing temps by more than 10C: not 56k friendly - Overclockers Australia Forums
[email protected]|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
