Old September 14, 2008, 03:56 AM
Infiniti's Avatar
Wow, what better is there than open air? (Having to do with air cooling though)
Old September 14, 2008, 07:08 AM
Dwayne's Avatar
Great thread, and lots of pictures... I like lots of pictures
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old September 14, 2008, 11:55 AM
Yeah Boldeagle very informative, and thanks for the links on how you did the mods. Gr8
Old September 14, 2008, 11:58 AM
If anything it was lapping the cpu and zalman down which helped with your cpu temp as well as proper or better TIM material.
Old September 14, 2008, 12:07 PM
Thanks buddy, the Zalman had a very nice finish already as can be seen but CPU lapping did make a significant difference. Very nice to get the Vid Card out in the open and imho this has made the greatest overall difference, removing the thermal backwash!
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
Old September 14, 2008, 04:05 PM
BrainEater's Avatar
Great post !
Good pics too .
I want to clarify something as far as lapping goes , forgive me if you know this , but I need to make sure.
'Surface Finish' is only a 'by-product' of lapping , it's really irrelevant if the lapping is done correctly.That's what thermal compound is for.
Lapping is a procedure to produce a Flat surfaces and/or mating surfaces.....'Flat' increases contact area , therefore cooling ability.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old September 14, 2008, 07:52 PM
Originally Posted by BrainEater View Post
Great post !
Good pics too .
Your thinking is spot on but more importantly the procedure I follow is about "exposing" the cooper element (removing the tin layer) and reducing the thickness of the IHS of the CPU which produces a greater thermal conductivity and thus "heat exchange" potential awhile creating a Flat Surface. Shiny surfaces are for girls and will produce negligible and insignificant differences tending towards the point of "diminishing returns". The TIM will fill in the voids.
Old September 14, 2008, 10:00 PM
I'm getting temp ranges "almost" comparable to water (which I'm avoiding altogether as phase or cascade is the next objective). Have a look at a fellow aussies build from an OC meet I organised :
http://i301.photobucket.com/albums/n...1/IMG_0114.jpg
http://i301.photobucket.com/albums/n...1/IMG_0115.jpg
For all pics look at:
Anyone up for an OC meet in Brisbane - Page 9 - Overclockers Australia Forums
  #19 (permalink)
Old September 15, 2008, 05:03 AM
yamawho's Avatar
I like the open style case you have there ... good job
  #20 (permalink)
Old October 17, 2008, 01:32 AM
Every now and then (very rarely in my case) someone from above looks down and smiles upon you giving you something you really want, I won this from entering this competition:
Vote for Team Australia heading to Gigabyte Overclocking Taiwan Comp & WIN PRIZES! - Overclockers Australia Forums
Overclockers Australia Forums - View Single Post - Vote for Team Australia heading to Gigabyte Overclocking Taiwan Comp & WIN PRIZES!
Naturally the HS array had to come off for inspection and application of a quality TIM. I was very impressed to note that the HS array had "weight" to it and it certainly wasn't a painted look-a-like cooper, it weighed at least 0.5Kg on our electronic bathroom scales (they will only goto 0.xKg so they were a bit coarse to get an accurate measurement). The NB passive cooler is also cooper and they boast an upto 30% increased cooling potential. Test will be conducted with and without this system to see if any differences can be found.
