Old July 29, 2008, 10:00 PM
lukaszr's Avatar
Default Looking for a 775 Socet CPU cooler
Ok, i am looking for an etremely good CPU heatsink.
I do not want to remove my motherboard at all, therefore i am looking for something that is push-pin or clip installation.
Can someone recommend something to me, budget is $100.00.
i am running an E8400 (not overclocking).
thanks!
VideoCard: BFG GeForce 9800GTX OC
Mobo: Asus P5N-T Deluxe 3-Way SLI nVidia nForce 780i SLI Chipset
Processor: Intel Core 2 Duo E8400 3.0 GHz
Memory: OCZ DDR2 PC2-6400 Vista Performance Platinum 4GB 800MHz
PSU: Apevia Iceberg 680-Watt
Old July 29, 2008, 10:04 PM
Infiniti's Avatar
Why don't you want to remove the motherboard? Its not too much work. If you change your mind, you should have a look at my FS thread. I have a Ultra 120 for $45.
Old July 29, 2008, 10:07 PM
thanks!
OCZ Vendetta 2 ..
Uses stock Pushpin.
$30
Old July 29, 2008, 10:10 PM
lukaszr's Avatar
Originally Posted by enaberif View Post
OCZ Vendetta 2 ..
Uses stock Pushpin.
$30
is it a good solid heatsink?
i have the OCZ Vindicator and i returned the thing cause the bracket for the push-pins wouldn't install correctly. really had me pissed off.
hows the OCZ Vendetta 2??
Old July 29, 2008, 10:12 PM
Infiniti's Avatar
I don't really like the "push-pin" mechanism just because I find it annoying to install. Thats why I like stuff that require taking out the mobo.. Much less PITA, just a straight forward process.
Old July 29, 2008, 10:25 PM
Vendetta ranks right up there with the Ultra 120 and in some cases people swear its better than the 120
Pushpins are ok for normal use but if you really want to push I suggest using a non-pushpin cooler.
Old July 29, 2008, 10:34 PM
misterlarry's Avatar
Pull the mobo and buy Infiniti's 120. I really like mine and pulling the mobo will let you get all the really old dust bunnies from behind it.
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - EVGA GTX960 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old July 29, 2008, 10:45 PM
lukaszr's Avatar
LOL - there are no dust bunnies back there, as i had just built this computer 2 weeks ago LOL.
I think i'll go for the OCZ for now, then by the end of the year, upgrade to something better...when i take apart the comp for cleaning :)
Old July 29, 2008, 11:10 PM
Infiniti's Avatar
Hmm.. Do I see a new water cooler? (at the end of the year?)
Old July 30, 2008, 03:56 AM
OCZ Vendetta 2 ..
Uses stock Pushpin.
$30
Thats a nice HS and after going to OCZ and clicking on the HWC reviews;
"- Great Cooling Performance (near water cooling levels!)
- Quiet fan
- HDT base works as advertised
- Great price
- Tool-less installation"
OCZ Vendetta 2 CPU Cooler Review
That looks like a good buy.
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
