Old July 30, 2008, 06:44 AM
yamawho's Avatar
Don't like the pushpins, they are a real pain to install and you never know when one can let go
Keep in mind that after market coolers weigh a lot more and are much higher than the stock HSF. The weight and leverage that they apply on the mobo can cause warping and lead to other issues ...
I have purchased several Zalman coolers over the years and I really like them. They have a quality construction and come with many adaptors to fit different sockets that have large back plates to support the weight. I even have some 7700Cu coolers that are installed on thier 3rd build 478 to 939 to 775.
If you don't plan to overclock, you can turn the fan speed way down and have a really silent system
lukaszr's Avatar
Originally Posted by Boldeagle View Post
Thats a nice HS and after going to OCZ and clicking on the HWC reviews;
"- Great Cooling Performance (near water cooling levels!)
- Quiet fan
- HDT base works as advertised
- Great price
- Tool-less installation"
OCZ Vendetta 2 CPU Cooler Review
That looks like a good buy.
well its definitely sold me :). I was going to buy the Asus Triton 79 for $65.99, but if this heatsink has such good reviews, and performance, i'll simply safe my $$ :). Ty for the help :)
VideoCard: BFG GeForce 9800GTX OC
Mobo: Asus P5N-T Deluxe 3-Way SLI nVidia nForce 780i SLI Chipset
Processor: Intel Core 2 Duo E8400 3.0 GHz
Memory: OCZ DDR2 PC2-6400 Vista Performance Platinum 4GB 800MHz
PSU: Apevia Iceberg 680-Watt
Old July 30, 2008, 09:58 AM
I'm selling this one: FS: HSF Enzotech EXTREME-X
Room Theater :
Xeon X3220+Thermalright Ultra-120 Extreme 4GB Corsair XMS2 TWIN2X2048 eVGA 9800GTX superoverclock 512MB 2*500GB (RAID 1) Western Digital 22inch LCD SamSung 226BW Hauppauge WinTV HVR-1800 HT Omega Claro Plus Logitech Z-5500
Portable:
Dell XPS M1530 Ipaq Hw6945
Old July 30, 2008, 06:59 PM
LCB001's Avatar
Folding Captain
Just installed the Vendetta2 on my Quad, great cooler. Like you, I didn't want to remove the MB on a a new build. Hopefully you have a lot of room in your case as it was a very tight fit in mine. Hope you got strong fingers...
Folding For Team 54196
Old July 31, 2008, 02:02 PM
Default Reply
I agree with the others. You can't go wrong with the OCZ Vendetta 2. Also don't forget to buy a decent fan. The Noctua P12 or the Scythe S-Flex "F" are both very good choices.
Old July 31, 2008, 05:14 PM
CTA's Avatar
CTA CTA is offline
- Quiet fan
- Great price
better than U-120 black edition?
< wants to use q9450
Old August 3, 2008, 09:37 AM
in most cases i've heard, yes all HDT coolers usually perform better than standard ones
