Old July 24, 2008, 12:47 AM
Default are they good?
are these fans good? anyone owns them? comments? thanks
http://www.ncix.com/products/index.p...ctic%20Cooling
Old July 24, 2008, 05:22 AM
JD JD is offline
Arctic Cooling stuff is usually decent, though that fan can only be used as an exhaust due to it's design.
You might want to consider the Scythe S-FLEX series though they cost twice as much.
Old July 24, 2008, 05:25 AM
CMetaphor's Avatar
Quadfather
I do so very love Arctic cooling fans. PWM sharing + super silent + affordable. The only one's that are quieter afaik are the Noctua fans, the low speed Scythes or Nexus fans - all of which cost more or much more. (I don't consider the faster Scythes silent because in my experience anyone of the 1600rpm models of higher have a whine to them when running at max.)
Old July 24, 2008, 05:58 AM
Chos3n's Avatar
Listen to that guy ^^
He didn't call his system Gale Force for nothing.
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card EVGA GeForce GTX 780
Sound Card ASUS Xonar DX
