Old July 21, 2008, 10:40 PM
Default Sunbeam Core Contact Freezer 4
It's after the fact since I have already ordered it but has anyone installed one of these coolers into a Antec 900? I got it to go with my Q9450 and it is only now, after the fact, that I start hoping it will fit
TIA
Build In Process (Over 4 months now)
Intel Q9450
Antec 900 - Asus Maximus Formula
4 GB Crucial PC-6400 - OCZ 750W
Visionteck 512MB 3870HD
Vista Home Premium 64 bit OEM
LG GGC-H20L Blu-Ray/HD Player
2 x WD SE-16 500GB Sata2 NCQ
Old July 22, 2008, 12:33 AM
Mibs's Avatar
well the most recent product review on NCIX for this says:
who needs water cooling when you got antec 900 + Sunbeam core freezer and cpu boosted at least 15% at full load = 35c
So this guy got it to fit. There's no real reason why it wouldn't fit anyway. If you want to be sure the measurements are there, just take a quick look with a tape.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 22, 2008, 12:53 AM
Yeah it should fit...though you won't have a lot of room left between it and the side panel.
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
Old July 22, 2008, 01:03 AM
Thanks guys,
I have never purchased a hsf having always used stock coolers. I made the purchase earlier today and it wasn't until I started a 12 hour shift at work that it occured to me "I wonder if it will fit...It should...but will it?" I am glad to know it should work.
Intel Q9450
Old July 22, 2008, 07:28 AM
I shoved one in my antec 300, and have the side panel fan installed.
