  #61 (permalink)
Old June 5, 2009, 07:42 PM
artistpavel's Avatar
Just ordered these 3 items, lets see what Vendetta 2 can do to get me to 3.6:
OCZ Vendetta 2 Triple Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 120MM Fan 800-1500RPM 20-32DBA - DirectCanada
Xigmatek ACK-I7751 Crossbow Mounting Kit for 3 Piece Heat Pipe for HDT-S963 HDT-S1283 RS-S1283 - DirectCanada
Arctic Cooling MX-2 Thermal Compound Paste NON-ELECTRICAL Conductive 4 Gram - DirectCanada
Is MX-2 as good as they say?
I wonder If I can turn Vendetta horizontally so the hot air blows up into the large Antec 900 fan, anyone tried that?
х58forLife
  #62 (permalink)
Old June 6, 2009, 07:02 AM
Hey.. Canadacomputers has a Vendetta 2 on sale.. and they have the official OCZ Backplate for LGA1366 / 775 for about the same money.
OCZ Vendetta 2 - $28.99 after MIR until June 16, 2009
Canada Computers - Cooling > CPU Cooling : OCZ (OCZTVEND2) Vendetta 2 CPU Cooler For Sockets AMD 754/755/939/AM2, Intel LGA775* .
OCZ Vendetta 2 LGA 1366 / 775 Backplate $10
Canada Computers - Cooling > Accessories : OCZ (OCZTFORC2V2) Force 2 1366 (i7) Retention Brackets - Vendetta Series.
The OCZ does come with paste applied..
  #63 (permalink)
Old June 6, 2009, 09:01 AM
Hey, thanks, but those brackets are for i7 socket, the 775 are out of stock at most retailers. How to properly clean those fins, with compressed air only?
х58forLife
  #64 (permalink)
Old June 6, 2009, 09:45 AM
MpG's Avatar
MpG MpG is offline
Actually, that V2 bracket does work for both 775 and 1366, although they're not very clear on that. If you look at the picture, you can see two set of mounting holes, one for each socket. I can vouch for that personally, as I'm using that exact setup right now.
  #65 (permalink)
Old June 6, 2009, 10:31 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
I know with the Xigmatek "crossbow" i7 version one side is 775 the other is for i7. I can't imagine there being any dif between the Xigmatek Crossbow and the "official" OCZ version ;)
  #66 (permalink)
Old June 6, 2009, 04:26 PM
IRQ Conflict's Avatar
I know someone who did this with an LGA775. Saved ~2c iirc. I was going to do that with mine but for got in all the excitement of a new MB. After reading the instructions on my tube of AS5 I found out it can take up to 200 hours of usage before seeing it's full potential I decised a remount wasn't going to be worth it.
  #67 (permalink)
Old June 6, 2009, 05:11 PM
Yes, V2 BRACKET does work on 775 AND 1366.
  #68 (permalink)
Old June 6, 2009, 07:24 PM
I made a quick diagram of Vendetta 2 orientation for cases with top fan.
2 things I'm worried about, not enough room due to RAM sticks and heat rising from video card going directly to Vendetta fan.
х58forLife
  #69 (permalink)
Old June 7, 2009, 02:42 AM
Well, It would depend on your ram size (mine are pretty tall), and won't work. The Vendetta is roughly 4-1/2" deep and 3-5/8" wide. My ram has monster heat pipes on top so it won't work for me. Maybe that is why I didn't bother changing the orientation. Long time I guess.
  #70 (permalink)
Old June 7, 2009, 08:25 AM
Thats how my setup was in my antec 900 with a m3a79-t and vendetta 2. I have normal sized ram though, and other boards may have different layouts, not to mention the fact that my board is am2 and that was the ONLY way i could mount it.
Thats exactly how it looked in the antec 900 as well, just barely any clearence before the top exhaust fan. Theres also this pic of it setup in my old antec 900, the pic is massive though and im too lazy to resize so ill just link to it http://i571.photobucket.com/albums/s...2/100_0192.jpg
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
