  #51 (permalink)
Old September 3, 2008, 07:28 AM
darius_m5's Avatar
The Vendetta 2 kept my E8400 @ 3.6 GHZ idling around 35 degrees. At stock speeds, it idled around 30 degrees. I love this cooler. However, it was a pain attaching the fan to the heatsink.
Asus P5Q-Pro | C2D E8400 @ 3.6Ghz | OCZ Reaper 2x2gb PC2-8500 | Enermax Infiniti 720W PSU | OCZ Vendetta 2 HSF | Cooler Master HAF 932 Case
Ati Sapphire HD4850 512MB w/ Accelero S1 | 2 x WD Caviar 320GB Sata HD | Pioneer DVR-215D Sata | Windows Vista Ultimate 64bit | Samsung 20" T200 LCD
  #52 (permalink)
Old October 3, 2008, 07:23 PM
Silvgearx's Avatar
hi, anyone have this in there antec sonota III? by its measurements it should be a perfect fit. i too am looking for a good cooler like this to replace my stock HSF. will also get the bolt thru-kit.
any thoughts?
Thank you
  #53 (permalink)
Old October 5, 2008, 08:25 AM
Mr. Gruntsworthy's Avatar
I have a Vendetta II--it's going on my new rig once it's finished :P
MAIN RIG:
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
http://mikeseguin.webs.com/
I run Durham 3D Printing, an online 3D Print shop!
  #54 (permalink)
Old October 9, 2008, 01:34 AM
Ok, got a Vendetta 2 for my new computer. I'm mounting it on my Assu P5e3 board.
Will it cause any bending? Should I get one of those back mount thingys? Or should it be fine?
  #55 (permalink)
Old October 9, 2008, 02:56 AM
Jon_di2's Avatar
Get the Bolt through kit!! (yes that is the back mount thingy) but it will be fine if you use the pins and don't have any trouble with them.... I did though, so I got the bolt through kit.
I got mine here:
Thermalright LGA775 Bolt-thru Board Mounting kit - (eBay.ca item 270263013831 end time 04-Nov-08 19:32:32 EST)
Only 8.61 US after Shipping to anywhere in Canada, and no taxes.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
  #56 (permalink)
Old October 9, 2008, 09:58 AM
paphman910's Avatar
I got mine here:
You can order it from Direct Canada or NCIX.
Paphman910
  #57 (permalink)
Old October 9, 2008, 03:34 PM
Il Duce's Avatar
A bolt through kit is a must have for this cooler. 2 of my push pins are already loosening up. Very annoying to re-adjust them whenever you move/clean your pc.
  #58 (permalink)
Old October 10, 2008, 01:59 PM
norfolk's Avatar
I am currently running this cooler on a AMD 9850 with great result"s .I may even consider this OCZ product for my 5000+ BE.Great cooler all in all.
  #59 (permalink)
Old November 3, 2008, 06:52 PM
any thoughts?
Thank you
I have the Sonata III as well as the Vendetta. No prob fitting in there.
I'd recommend you get the bolt thru tho. . . . .mine actually fell off yesterday! Plus, there no local stores that seem to carry the thermalright bolt-thru .. . .
  #60 (permalink)
Old November 8, 2008, 11:13 AM
Neolithium_Wpg's Avatar
The Vendetta's been such a sport for performance lately, I think I'm scrapping my Water Cooling and just gonna see how good things go when I buy a new CM HAF and give the wife my Antec 900 LOL. I really can't complain about any cooler that has my 3.4GHz Q6600 nicely at 55C full load.
Dell XPS8700 | Asus x101ch | iPhone 5 (iOS7)
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
