Old July 15, 2008, 06:28 AM
1Tanker's Avatar
Default Thermalright Ultra-120 A & SI-128 SE Review @ X-bit
X-bit labs reviews the TR Ultra-120A & the SI-128 SE. The results are quite surprising.
Without giving too much away... let's just say...i want an SI-128 SE now(i already have a TRUE )
Linkage
Old July 15, 2008, 06:49 AM
3.0charlie's Avatar
The processor Vcore was increased to 1.5625V in the mainboard BIOS (1.53~1.54V according to the monitoring utility).
They want to kill their QX9650 or what? And it's way too much voltage for 3.9GHz - mine needs 1.47V for 4.2GHz stable...
I'm surprised thought by the performance of the SI-128, specially being a downdraft HSF.
Hydro-Quebec is salivating...
Old July 15, 2008, 02:54 PM
1Tanker's Avatar
Yeah..impressive. I've loved my XP-120, but it's nowhere near as good as my TRUE. The SI-128 SE is, and cools mobo components as well. I also like that a side-panel fan can blow fresh air towards the HS's fan... or better yet, run a duct from the side-panel fan straight to within ~1/4" of the HS.. that'll work very nicely.
Old July 15, 2008, 03:18 PM
Cptn Vortex's Avatar
My XP-120 is great too. Run it on my server, it is never an issue.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old July 15, 2008, 04:14 PM
1Tanker's Avatar
I put (1.60v@BIOS..1.5625@CPU-Z) into my E8400, cooled by my TRUE(and many 120mm fans..open bench) for hundreds of benches(Forum Wars 08) and for 2-3 weeks, which ended around mid-April...and she's still running like a top. I believe that too much VTT can kill the 45nm chips..not "just going over 1.40v".
Old July 15, 2008, 04:36 PM
3.0charlie's Avatar
Interesting. I know about VTT, but what about 24/7 Vcore? I've read 1.475V (taken from cpu-z), have you seen any higher?
As for the side panel mod, I did that with a Zalman AlCu7000, which lowered the temps greatly. My case (back then, a Chenbro) had a side panel opening and an air duct already installed. I modified it just like you said, but the end was a modified plastic bowl that matched the diameter of the Zalman - that meant about 1/8" clearance from the HSF... Worked great! Heck, you could feel the suction from outside the case.
Old July 15, 2008, 09:12 PM
1Tanker's Avatar
First of all.. yeah, 1.5625v is pretty high vCore for 3.9GHz ...they must have used more voltage than necessary to increase the heat load. Generally, what i've seen a lot of the guys on XS saying, is 1.37-1.40 vCore(real) for 24/7. I usually run 1.40-1.50v depending on the temp in our computer-room. If it's a warm summer day, but not hot enough for the A/C..i'll drop the clockspeed if unneeded. If it's a winter day(i'll open the window) or hot summer day with the A/C blasting.. i'll pump up the clockspeed. Yeah, ducts are very effective, i even built one out of a Coke case.. and it lasted a few years.
Old July 16, 2008, 01:22 PM
3.0charlie's Avatar
Meh... you don't need 1.5625V to generate a heat load with a QX9650... and thanks for the info: mine runs in the same ballpark.
