Will air cooling do the trick?
Hi guys
Im about to buy asus rampage, intel q9450, dual 4870x2(when it comes out), antec 1200 gaming case w/ side fan, xigamatek s1283(push pull config),
my question is will there be enough airflow within the system?
will the xigamatek s1283 with push-pull(2fans) config fit the asus rampage not affecting the NB heatsinks?
are there active coolers for videocards ,ram, and NB that i can mount LOL
i think im askin too much but thanks in advance
Is TRUE really that good? can xigamatek rival it? how about the TRUE's Quality issue, has it been resolved? Im confused of what to get i have 100$ of budget? but i want the quality and performance? if ever ill be using a push pull config what can u suggest/say?
