Old July 9, 2008, 04:47 AM
Infiniti's Avatar
Default Thermalright Ultra-120 not so great?
Hey all, I just went to Anitec recently and bought an Ultra 120, I finally went and installed it just a moment ago. When I turned on my computer, the temps from BIOS was 29C, so I thought, not bad. I then left my computer on, and when I came back, the idle temp was 40C! I used Orthos to stress my CPU, and the temps went up to 60C.. Even my stock cooler was better.. I tried remounting, but the temps were still the same.
Any Ideas?
Old July 9, 2008, 05:05 AM
FrankyG's Avatar
You might have put too much thermel paste on the CPU ?? I have one of these on a overclocke E6850 @ 3.81Ghz and my temps never go over 55 full load...
Intel i7-5820K, MSI X99 SLI Plus, 16GB DDR4, Geforce GTX980
Old July 9, 2008, 05:08 AM
Infiniti's Avatar
I don't think so. I used the AS5 instructions on how to apply TIM on a dual core, but then again, the MX-2 tube opening is bigger than the one on the AS5.. Maybe I did put too much..
I'll remount and come back with some temps soon.
Old July 9, 2008, 05:37 AM
Synth's Avatar
Put a coin (a quarter) between the heatsink and the mounting bracket to increase pressure and tightness...
Old July 9, 2008, 06:15 AM
Infiniti's Avatar
Wouldn't that make the heatsink too tight then?
Anyways, I remounted the heatsink, and reapplied the TIM. I read online that I should put a grain size splotch in the middle of the CPU, so I did that. My idle temps are now still 40, but load is 50 now. A little improvement, but I am still disappointed..
EDIT: I just tried the coin thing, but now my temps are back to when I had 60 as load..
Old July 9, 2008, 06:48 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Which fan are you using on the cooler?
Old July 9, 2008, 06:53 AM
Infiniti's Avatar
I'm using the Scythe Slip Stream fan, the 800RPM version. Heres a link: http://www.ncix.com/products/index.php?sku=26746&vpn=SY1225SL12L&manufacture=Sc ythe
Old July 9, 2008, 07:01 AM
Mibs's Avatar
Running a fan with a higher RPM will definitely give you some improvements. When I switched to a Noctua NF-P12 from some generic fan with lower RPM there was a noticeable drop in temps. I've also got an overclocked chip (e6750) with a TRUE and it as well never goes over 55C on full load, and that's on a hot day (well hot for Newfoundland anyway...) I think the best way to apply AS5 to a Core 2 Duo is just a thin strip from top to bottom in the middle of the IHS.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 9, 2008, 07:44 AM
Infiniti's Avatar
I just put a 1200RPM Scythe fan on the HS, and now, I am getting 33-36C idle and 40-48C load.. Quite an improvement.
Old July 9, 2008, 07:50 AM
SKYMTL's Avatar
NOT a good fan for that heatsink. You should be looking for something like a Yate Loon or Noctua P12 1200RPM which should drop your temps by at least 10%.
