Originally Posted by Mibs 35C ambient! Ouch how can you sleep! That would definitely explain those high temps. Trying to gauge temperature readings in the middle of the summer is obviously pretty tough. Lower those ambient temps and you will most definitely see an improvement. As for the paste in the socket, that contact cleaner is a great thing to use. When I had an rma board sent to me from evga once it had what looked like AS5 in the socket. I was afraid I was going to fry the entire system with that stuff in there, but I just soaked it with that contact cleaner and used a toothpick to get out the rest and it worked just fine. |
Yeah.. sleeping is pretty hard.. I have to not sleep in one night just to sleep on the other..
I should really get an AC.. I was about to, but there was this week about a month ago where it was so cold, before that I decided I needed an AC, but I guess the weather changed my mind, and I spent that money elsewhere.
About the paste in the socket, yeah, contact cleaner is a godsend.
Originally Posted by enaberif Close your case and get some better air cooling through it.
What fan you go on your 120? |
Umm.. The fan I got on it is the sycthe slip stream 1200RPM fan.
