  #41 (permalink)
Old July 10, 2008, 06:19 PM
Infiniti's Avatar
Thats great to know. No need to redo the whole thing..
  #42 (permalink)
Old July 10, 2008, 08:47 PM
Infiniti's Avatar
Woohoo! I finished! I am so proud.. Time to grab a beer.
My CPU isn't shiny at all, but my ultra 120, ITS AWESOME! I don't really care if my CPU is shiny or not, as long as its flat.
I'll post some pics in the next post because I need to upload them.
Also, something that is totally off topic, is it okay to have some MX-2 in the CPU socket pins? it got in when I took out the CPU.. Looks like I put on too much TIM..
EDIT: Looks like you guys won't be getting any pictures.. The camera's dead.. (Literally)
  #43 (permalink)
Old July 11, 2008, 04:46 AM
Infiniti's Avatar
Help, anyone?
  #44 (permalink)
Old July 11, 2008, 05:12 AM
zlojack's Avatar
Help, anyone?
I wouldn't like to have it there. But apparently it's non-conductive.
  #45 (permalink)
Old July 11, 2008, 05:57 AM
Infiniti's Avatar
So that means its okay if its in there right? Because I was in this situation once already, but this time with MX-2. It was AS5 last time, so that made me worry. But maybe MX-2 should be fine... Anyone know for sure?
  #46 (permalink)
Old July 11, 2008, 06:04 AM
magictorch's Avatar
Its not conductive but you dont really want it in the socket. If you find a very fine paint brush and apply some arctic clean (or something like that to it) and carefully brush it off the pins. Leave the pins to dry before adding the chip perhaps.
  #47 (permalink)
Old July 11, 2008, 06:12 AM
Infiniti's Avatar
Damn.. I guess I should just use some aerosol contact cleaner to spray it off.. Thanks for all the help though, I really appreciate it.
  #48 (permalink)
Old July 11, 2008, 07:09 AM
MpG's Avatar
MpG MpG is offline
AS5 is technically non-conductive, actually (the silver particles are in suspension). The problem is that it's capacitive, which will cause problems if it gets into the socket. MX-2 claims to be both non-conductive and non-capacitive, so theoretically you should be just fine. In your place, I'd still be trying to clean it out, but if you don't get every last spec, I wouldn't be losing any sleep over it.
  #49 (permalink)
Old July 11, 2008, 07:42 AM
zlojack's Avatar
+1
What he said.
  #50 (permalink)
Old July 11, 2008, 07:47 AM
Infiniti's Avatar
So, I should really just make sure that the stuff aren't on the tips of the pins which will touch the CPU, right? If they are on the bottom, it should be fine, right?
