Old July 8, 2008, 05:36 PM
Level up: 67% Level up: 67% Level up: 67%
Level: 8 - 60 points to level up
Default What is better?Air Cooling
What is better? Sunbeam Core Contact Freezer or the Xigmatek HDT-S1283 in
cooling the cpu?
Old July 8, 2008, 05:51 PM
Cptn Vortex's Avatar
Level up: 48% Level up: 48% Level up: 48%
Level: 24 - 869 points to level up
Probably both?
The Vortex H20
DFI X38 LT
Xeon X3210 @ 3.2GHZ 1.30V
PNY 9800GX2 (750/2200)
4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V
Ultra X3 1000W PSU
Auzentech X-fi Prelude
2x500GB Hitachi RAID 0, 250 Seagate
Sharp 32" Aquos 1080p
Benq W500 1080i Pojector.
Watercooling:
D-Tek Fuzion Bowed, MCR320+Gelid Silent 12 Fans, MCP655w/EK top, EK Multioption 100ml Res, DD 9800GX2 block, MCW30, MCR320+Gelid Silent 12 fans.
Old July 8, 2008, 05:59 PM
jdrom17's Avatar
Level up: 47% Level up: 47% Level up: 47%
Level: 24 - 888 points to level up
Frosty Tech says the Sunbeam, however it more depends on the fan you use on the heatsink. I don't think they use the same fan on all the heatsinks they test. However using the fan that comes with it, the Sunbeam apparently is a bit cooler though also noisier.
Old July 8, 2008, 06:03 PM
so what do you guys prefer out of the two?
Old July 8, 2008, 06:04 PM
Which is cheaper? Choose that one. Then get a nice fan of your choice
The Vortex H20
DFI X38 LT
Ultra X3 1000W PSU
Watercooling:
Old July 8, 2008, 06:42 PM
what fan can you recommend me?
Old July 8, 2008, 06:54 PM
Scythe S-Flex are awesome. Are you a noise freak?
The Vortex H20
DFI X38 LT
Ultra X3 1000W PSU
Watercooling:
Old July 8, 2008, 06:57 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
Noctua NF-P12-1300.
Nam et ipsa scientia potestas es
Pax Pro Eo Optimus Arma
heu, modo itera omnia quae mihi nunc nuper narravisti, sed nunc anglice?
www.nopperdogs.com
Old July 8, 2008, 07:06 PM
Noctuas are great...but untill they ship without that god awful colour....I will never buy one.
The Vortex H20
DFI X38 LT
Ultra X3 1000W PSU
Watercooling:
Old July 8, 2008, 07:31 PM
CanadaRox's Avatar
Level up: 16% Level up: 16% Level up: 16%
Level: 14 - 491 points to level up
I second the S-Flex. They are about even with the Noctua P12's, but when some restriction is put on the airflow (radiator, heatsink, etc) the S-Flex pulls ahead. But, if you don't mind some noise, there are many extremely powerful 38mm thick fans that will provide lots of airflow and pressure, but they are loud. If you can find it, the San Ace H1101 is probably the best fan out of all high speed fans (high speed bing 100-130CFM), but it is nearly impossible to find and costs around $20-25.
Project: Black and White
Old July 8, 2008, 09:13 PM
Level up: 88% Level up: 88% Level up: 88%
Level: 9 - 30 points to level up
Default Reply
Third the S-Flex. I'd get the Sunbeamtech C.C.F.
Personally if I wanted kick-@$$ cooling with air, I'd get a TRUE with push-pull fans.
Old July 8, 2008, 09:16 PM
Level up: 29% Level up: 29% Level up: 29%
Level: 12 - 287 points to level up
I'm a fan of Panaflos. Almost every single 120mm I run is a Panaflo. Except in the damn P182SE which is designed for "thin" 120mms and not the 38mm of a Panny.
Old July 9, 2008, 11:32 AM
what is push pull? LOL :P if i bought the s-flex fan can i mount it with the sunbeam CCF? like the fan it come along with? do i have to buy extra clips, to safely mount the added fan? can i use two fan configuration? what is the best the two fans running as an exhaust or one that push air in and one that push air out? hehe thanks for your replies
Old July 9, 2008, 04:13 PM
SugarJ's Avatar
Level up: 66% Level up: 66% Level up: 66%
Level: 20 - 374 points to level up
Push Pull configuration is better.
Intel i7 920 EVGA X58 Classified Asus GTX285TOP, Xonar DX Silverstone TJ07 "Murdermodded", Strider 850W OCZ Vertex
WC Loop: Heatkiller 3.0 MCP655 Feser 360 EK 150 Res
