Old July 8, 2008, 12:22 PM
Jack Rabbit's Avatar
Originally Posted by Cptn Vortex View Post
Not too sure what you are talking about. My 3 2200RPM fans all spin at 2200RPM.....when I have them all spliced together.
I am going to guess you have them in parallel, then.
- James Graham
Old July 8, 2008, 12:25 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by Jack Rabbit View Post
It is correct that you would be dividing the voltage. I believe my statement is also correct. Resistive loads (which is what motors basically are when not at stall speed) placed in series will have the voltage and current divided among them in direct proportion to their resistance. Since they are all, probably, very similar loads they would get almost equal amounts of both.
Actually, you don't divide the current across a series setup, since the current is constant throughout the entire circuit. However, in a series circuit, the resistance values are added up directly, which has the effect of increasing the circuit's total resistance, which naturally lowers the current passing through it.
Old July 8, 2008, 12:39 PM
DK2 DK2 is offline
The current doesnít actually divide though; itís the result of the two fans dividing the voltage between them.
The whole circuit then draws half the current.
The same current flows through both fans.
In parallel the current divides down the two paths provided,
then the whole circuit draws twice the current.
I know, picky picky eh?
Old July 8, 2008, 12:58 PM
Cptn Vortex's Avatar
like this. Simple.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old July 8, 2008, 01:05 PM
DK2 DK2 is offline
bingo, remember only use the yellow rpm wire from a single fan leaving the 'extra' ones unconnected.
These are outputs from the fans, if you connect them together and one gives a high
signal as the other gives a low, you have a short condition.
Old July 8, 2008, 01:06 PM
Ok, yeah, you guys are right the current is not divided (or distributed) in series. If the individual devices in the chain have different resistances the voltage drops across each one will vary. The total current will be affected by the increased load. That is where I got confused.
Yeah but that is good. It has been too long since I studied resistor theory.
- James Graham
Old July 8, 2008, 01:11 PM
like this. Simple.
/thread
Thanks. That's exactly the explaination I was looking for.
Old July 8, 2008, 01:17 PM
DK2 DK2 is offline
Occam's razor wins again, damn
