Old July 8, 2008, 01:24 AM
Default Fan "A" vs Fan "B"
Fan "A" is the coveted San Ace 1011:
Current: 0.52A
Power: 6.24
RPM: 2600
CFM: 102.4 CFM
Pressure: 64.7Pa (6.6mm)
Noise: 39.0
Fan "B" is a unknown fan from a electronics shop:
Current: 1 Amp
Power: 12 W
Speed: 2400 RPM
Max Air: 121 CFM
Max Pressure: 5.6 mmH2O
Noise: 46 dBA
So the Fan "B"s are worth about $20 but ... look at their amperage and watts... its almost double of that of the san ace .. haahahaha. Its odd tho as it pushes more CFM at a lower speed but has a lower static pressure.
Old July 8, 2008, 02:17 AM
MpG's Avatar
MpG MpG is offline
You've got some 1011's? Nice! I know Vapor over on XS actually verified that the San Ace's were nearly spot-on in their specs.
Are the blades on the mystery fan abnormally shaped? It's not impossible that a design might sacrifice static pressure for open flow, but I don't think I've ever seen a 120mm fan verified to push 120cfm at only 2400rpm. Even the good ones seem to need about 3000rpm before that happens.
Old July 8, 2008, 02:29 AM
Not yet.. I'm lookin to pick some up. but its like the damn holy grail of fans hahaah.
But I think I found a contender :D
# Size 120x120x38mm
# Air Flow 175 + CFM
# Noise 58 dB(A)
# Connector 3 pin
# RPM 3800
# Rated Voltage 18.20 Watts
# Rated Amparage 1.60 amps
# Modle # MD1238H
18.20watts @ 1.60amp!
yeehaw hahahahaha.
Old July 8, 2008, 12:29 PM
MpG's Avatar
MpG MpG is offline
18W on a three-pin connector? Better aim that fan at the motherboard plug to keep it cool!
Old July 8, 2008, 12:55 PM
Cptn Vortex's Avatar
Very cool design! Also, I would have gone for the San Ace fans too, but where to get them??
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old July 8, 2008, 01:11 PM
Jack Rabbit's Avatar
and put a serious grill on it so no one loses a finger or a paw.
- James Graham
Old July 8, 2008, 01:47 PM
Dashock's Avatar
dam now thhats a sexy looking fan but wayy too loud for my liking!
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old July 8, 2008, 03:23 PM
cegras's Avatar
I've seen the brand mechatronics, so they're not really 'unknown', per say.
Old July 8, 2008, 08:10 PM
Default Reply
Am I deaf yet?
Anyway, why do you need high speed fans like these ones? And where'd you get your hands on the San Aces?!?!?! Those things are rare.
Old July 8, 2008, 08:16 PM
Originally Posted by freakgeek1337 View Post
Am I deaf yet?
I didn't.
Everywhere I found who had them listed were out of stock.
One guy said the Macros were pretty good too.
Whats nice about fans like that is you can undervolt them to be able to get pretty results.
