Old July 7, 2008, 12:56 AM
Damn you want the rig in another room so you can hear yourself think, all other case fans will have their bearings stripped by being forced to go faster than the can by the wind vortex that will be generated. Make sure you "super-glue" all of your jumpers down! Nice way to clean the case out though, but make sure you have a filter on the inlet and watch the cat.
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
Old July 7, 2008, 01:05 AM
That's why I'm planning on order 100ft of tubing. WC rig is going downstairs. Monitor/KB/Mouse are going upstairs.
I'm also gonna tape 8 to a small pig to see if I can make him fly.
Old July 7, 2008, 07:12 AM
Mulder's Avatar
Deltas move loads of air, sure they make lots of noise to, they also do some serious damage if you stick your finger into one of them. I had an older delta fan for a heat sink on a P3 and one of my friends stuck his finger into it and the fan exploded and he received some very nice cuts. Delta's are also annoyingly loud that 60-80db fan scream is 24/7/365 and your going to hear it a few rooms away from you pc and it's going to be constantly running.
Old July 7, 2008, 04:00 PM
I normally say fan grills are for sissies, but I took precautions and ordered enough to cover each side. Just in case...
Old July 7, 2008, 04:03 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I have a vantec tornado that flys if it is not fastened to something. Havent used it years though, can't handle the noise.
Old July 7, 2008, 04:17 PM
Cptn Vortex's Avatar
D-H.....100ft tubing....are you MAD??? How many pumps do you have.....
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old July 7, 2008, 04:30 PM
matsta31's Avatar
I re-read the small flying pig joke to make sure I read right. LOL
Sold hardware again.....
Currently using WHS hardware....
Old July 7, 2008, 06:08 PM
I'm ordering a 3rd CPU block. Why? It was cheap.
It only works out to about 33ft per computer...
  #19 (permalink)
Old July 7, 2008, 06:11 PM
I see your 8 deltas and raise you 550cfm
RP Electronics - Test Instruments , Power Supplies , Inverters , Electronic Project Kits and more!
  #20 (permalink)
Old July 7, 2008, 09:04 PM
MpG's Avatar
MpG MpG is offline
The sad thing is, that beast of a fan has about the same power consumption and less noise. Quite a bit lower static pressure though. You need raw rpms to generate that.
