Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old June 30, 2008, 01:06 PM
sircuster's Avatar
Level up: 62% Level up: 62% Level up: 62%
Level: 10 - 107 points to level up
Default e-Sata Coolers
Here is a rather cheap solution for cooling external hard disks. I decided on this, since I already had external Sata ports on my GA-P35-DS3R.
E6750 / Gigabyte GA-P35-DS3R
Sapphire HD3850 512 GDDR3
2x Corsair XMS2 TWIN2X2048-6400C4
ASUS DVD-ROM Sata/LG DVD Burner Sata
2x WD Raptor 36GB Sata 150
1x Seagate ST3320613AS
1x WD 500GB Sata II
Hauppauge PVR 250
Creative Audigy ZS
Antec TruePower Trio TP3-650
Old June 30, 2008, 01:43 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Cool what is that? Did you make it?
Revolutionary Mule!
Old June 30, 2008, 01:55 PM
jay51's Avatar
Level up: 90% Level up: 90% Level up: 90%
Level: 8 - 18 points to level up
really good idea,i actually have 2 or 3 myself at under $5.00 i couldnt refuse,lol
mine are only single fan tho,but should work the same
thanks for the idea :) may put them to good use now..
there basic 3.5" hdd coolers
Old June 30, 2008, 08:46 PM
sircuster's Avatar
They are a set of hard drive coolers, I used on my old K7 rig. With my new case, I no longer needed them and they served the purpose. I used the fan mounting screws to connect them together.
It works real good too. Keeps the disk real cool (cooler than when in the case).
You can actually attach 2 drives and stand the ebit on it's side. I bought a hard drive dock to replace it, but the drive runs to hot, so I stick with the homey contraption. It's quite quiet as well.
I am glad you like the setup.
1x WD 500GB Sata II
Hauppauge PVR 250
Creative Audigy ZS
Forum Jump
Search this Thread:
Advanced Search
