  #21 (permalink)
Old June 29, 2008, 09:03 AM
this picture for example would the antec fan we cant see for the logo would it be facing the same way or opposite
  #22 (permalink)
Old June 29, 2008, 09:06 AM
Theres two faces to a fan.
1) Open faced
2) Bars
Bars = Direction of airflow.
So the antec in the picture is pushing air the wrong way through that cooler.
  #23 (permalink)
Old June 29, 2008, 10:13 AM
so the logo should be towards the heatsink?
also is there a temperature monitor that doesnt control fans but just tells you the temps?
edit: i think i got it
do u want both fans blowing air towards the heatsink or do u want one that is pushing air at the heatsink and one that is pulling air to the exaust in your computer?
  #24 (permalink)
Old June 29, 2008, 11:19 AM
heres a temp monitor http://www.ncix.com/products/index.p...facture=Scythe
1 pushing 1 pulling sounds correct
  #25 (permalink)
Old June 29, 2008, 11:21 AM
2nd option
  #26 (permalink)
Old June 30, 2008, 07:33 PM
after looking at the fans i was going to get i realized how fing loud they would be
6x of this http://www.ncix.com/products/index.p...e%20Technology
so are there any quiet fans that are 90cfm-100cfm or if rubber grommets would help alot?
thanks
