Old June 16, 2008, 11:43 PM
Eagle Eye's Avatar
Default ThermalRight T-Rad2
A preview of the new ThermalRight T-Rad2 is available on their website I am not sure if anyone has posted it yet, regardless it sure worth a look at looks to be a quite promising product. Hopefuly it will have compatibility with the new GTX 280 in the near future.
Check it out here Ultimate CPU Cooling Solutions! USA and here is a little info and a pic for a preview
Features
  • Light and Slim designed heatsink; 25mm in total height with large cooling surface area.
  • Options to install two 92mm fans or one 120mm quiet fan.
  • Supports multiple nVidia and ATI video cards in SLI and Cross Fire mode.
  • Six nickel-plated heatpipes to reduce oxidation effect, maintaining top performance for long term usage.
  • Features an all copper base and soldering technology that has each heatsink fin soldered to the heatpipes for a definite contact in producing high efficiency rate of heat transfer.
  • Vast compatibility with nNvidia 9 Series and ATI 3000 Series video cards.
Old June 17, 2008, 07:49 AM
DK2 DK2 is offline
The heatpipes offset to one side look a little wierd.
By the sounds of the 280 reviews and the heat output, I'm sure thermalright will be all over it.
Old June 26, 2008, 01:13 AM
This looks awsome imo. I hope they make a version for the 4870.
Old June 26, 2008, 09:24 AM
MpG's Avatar
MpG MpG is offline
Since it fits the 3800 series, it's quite likely to fit the 4800 series, since they have the same mount pattern.
