Old July 9, 2008, 11:39 AM
Originally Posted by jdrom17 View Post
It can be solved...
http://www.hardwarecanucks.com/forum...ur-change.html
[Photobucket is being uber slow right now so the pics aren't loading]
I really don't recommend this simply because you will be adding minute weight to the fans which is not intended.
The Noctuas can be pretty over hyped fans.
Old July 9, 2008, 11:44 AM
Why are people so worried about the colors? I agree with enaberif - this does add weight and possible stress the bearings if the paint is not spread evenly on the fan.
Noctua fans are great but the reason why they seem overhyped is due to the fact that they go down a route other manufacturers don't - namely, they go performance AND silence.
| Stock Q9450 + Noctua NH-U12P Cooler | ASUS Rampage Formula X48 | Corsair TX750W PSU |
| Corsair Dominator 4x2GB | 1x Sapphire HD 4870 + ThermalRight HT-03 |
| Seagate Barracuda 500GB 32MB Cache | Samsung 2253BW 22" LCD |
| Antec 1200 Case | Windows Vista Ultimate 64bit |
Old July 9, 2008, 11:47 AM
He used a "dye" but even so its gonna add extra weight even if its like .000000000002g
