Old May 4, 2008, 07:15 AM
Default The SilentFlux ATX
These look interesting, anyone ever use one? There is a review on Hard OCP about them..
Noise Limit - noiseless high-end cooling for CPU, PC and Workstation
[H] Enthusiast - Noise Limit SilentFlux CPU Coolers
I think we might see more like this in the future.
Old May 4, 2008, 08:28 AM
vinister's Avatar
I was all excited about it at first, looks like great technology and I love its industrial look.
But its louder than the Noctua, performs worse than a stock intel cooler, and is the most expensive aircooler you can buy.... Is there something I'm missing or is this thing an Epic Fail?
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old May 4, 2008, 08:35 AM
JD JD is offline
Looks extremely similar to the AKASA REVO which came out months ago... At least the REVO used a 92mm rather than a 80mm.
Here's a review of it: DriverHeaven.net: Akasa Revo Cooler
Old May 4, 2008, 08:56 AM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
Seems to be an answer in search of a question. Though I think if I had one I'd "duck tape mod" it to accept a 120mm :)~
if your opponent has a conscience, then follow Gandhi. But if you enemy has no conscience, like Hitler, then follow Bonhoeffer. - Dr. MLK jr
Old May 4, 2008, 09:12 AM
3.0charlie's Avatar
Looks very similar to the Vapochill Micro: asetek A/S.
Hydro-Quebec is salivating...
Old May 4, 2008, 04:22 PM
They are all interesting, I think the design can be improved upon for sure. I look the looks, I hope they can come up with a good design that functions equally as well.
