Old January 22, 2014, 09:31 AM
Default PWM Fan Splitter For 3-Pin Fans?
I have two Gelid PWM fan splitters that I have lying around.
If I cut the PWM wire on the splitter could I not use the splitter as a regular 3-pin splitter to control speed off my fan controller?
Old January 22, 2014, 01:36 PM
ZZLEE's Avatar
do not need to cut. !
It will work as a 3 pin cable no problem. just plug in your fans.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 30, 2014, 04:43 PM
Depends on which Gelid PWM splitters you have.
If they have PWM splitters with molex/sata connection to PSU cable you will have 3-pin fans spinning at full speed on 12v power from PSU.
if they are simple "Y" PWM splitter than they will work with no modification as ZZLEE said.
Old February 13, 2014, 11:15 AM
They have the Molex on them. That makes sense. Always wondered why they either spun at 100% or 0%.
:D
Thanks guys!
HDMI splitter from PC? sswilson HTPC Systems & Software 11 January 9, 2014 06:22 PM
3 pin fan splitter cables, or fan splitter station (bitspower, fractal etc)? Sheep Air Cooling 4 August 28, 2012 10:19 PM
[WTB] 3-pin Fan Splitter (3-way) tragd Buy/Sell & Trade 4 September 19, 2010 12:09 PM
CPU Fan Splitter Plug FreeKnight Air Cooling 5 February 8, 2010 09:53 AM
Fan Controller : Can you use a Splitter? BobbyLou Air Cooling 5 December 8, 2009 11:57 AM
