Old January 16, 2014, 12:07 AM
Shadowarez's Avatar
Or could try out the New phantek cpu coolers they look rather good. I'm getting the huge duel 140 for a backup of my swiftech H320.
Old April 16, 2014, 10:26 AM
The Buzz Kill's Avatar
from what ive read the D14 performs a little better at full load. The U14s only performs better at idle which doesn't mean much.
Old April 18, 2014, 07:04 AM
Though I have never used the newer version and still use the D14
Using the D-14 with Noctua PWM fans
I did try it with the new larger Noctua PWM fans but not much difference there maybe a degree if that
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old April 18, 2014, 08:44 AM
Condolences should be offered to the OP if the trigger was already pulled on the purchase. Noctua released a proper replacement, the NHD15 and from the reviews I read it blows everything before out of the water.
Noctua NH-D15 Review | ChipLoco
Noctua NH-D15 Dual-Tower CPU Cooler Review | Modders-Inc, Case Mods and Computer Hardware
Old April 18, 2014, 09:13 AM
lowfat's Avatar
Of course it will do better in those reviews using the stock fans. They are running 300 rpm faster than the fans on the D14.
Mael
Big Lian Li
Forever Alone
Old April 18, 2014, 01:32 PM
gotta give it to noctura though they really listen to feedback and improve on their products.
Old April 18, 2014, 01:58 PM
OP stated he was waiting, so I'm sure he'll be picking the D15 up :).
Old April 18, 2014, 02:10 PM
I just bought a d14 two weeks ago lol. bad timing i guess.
Noctua NH-U14S & NH-U12S Review Comment Thread SKYMTL Air Cooling 10 June 17, 2013 07:04 AM
