Old January 11, 2014, 02:21 PM
sakage.shinga's Avatar
Default Replacing fans on my Corsair 600T SE White
Hey guys,
The stock case fans on my Corsair 600T SE White are kind of "meh" (76cfm max) and I'd like to replace them with something that gives better airflow and heat dissipation into the ambient.
I was looking at the Bitfenix Spectre Pro for the two 200mm front/top and single 120mm rear fans. They seem to give great airflow yet not so noisy.
(EDIT: Just realized that the case fans are 20mm thick, vs. 30mm for most others...)
Any better suggestions?
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old January 11, 2014, 06:22 PM
Spikemaul's Avatar
You can use any 200mm fan in the front if you move the drive cage inward but if you do this you have to remove the top drive cage though. Here's a pic that might help ya out.
Old January 11, 2014, 09:32 PM
BigPhatPaulie's Avatar
you can also fit 2 120mm fans in the front (works pretty well) and the top is meant to handle that as well so theres another option
FOR PONY..... that is alll
Old January 11, 2014, 09:54 PM
Thanks for reply! Would two 120mm fans offer better cooling than one 200mm fan?
Old January 11, 2014, 10:53 PM
When I used my 600t (still have it actually) it did seem to push more air ( used 2 cooler master.r4 fans)then the.factory 200mm while still.fitting infront of the drive cages
Old January 12, 2014, 12:40 AM
Well right now I'm thinking of replacing the top 200mm exhaust fan with TWO NF-F12 fans, and also the rear 120mm exhaust with a single NF-F12. I may or may not do the same with the front intake fan but since I need all hdd drive cages to stay in I may not have room to fit in a 25mm thick fan.
Corsair 600T White esperasoppa Price Check 1 August 22, 2012 04:41 AM
[FS] Corsair 600T Special Ed White (with window) Evochuck Buy/Sell & Trade 1 September 18, 2011 06:28 PM
Corsair Graphite 600T White Review Comment Thread SKYMTL Cases 25 July 20, 2011 12:54 PM
