Old November 23, 2013, 05:47 PM
JohnWayne's Avatar
Default NoFan cr-95c
Thinking about putting one of these on a i7 4770S 65W. Any thoughts?
Old November 24, 2013, 06:23 PM
I head they are great for silent builds or extremely quiet if you use a few very low speed fans to circulate the air. Beware though, it will overhang the first pci-e slot of the motherboard and make it useless. Same thing for RAM with tall heat sinks.
Check out the OC3D review @
Old February 25, 2014, 02:01 PM
I would be scared to put one on
