Old October 20, 2013, 05:42 PM
icodeit's Avatar
Thumbs down Corsair SP 120 - To short of wires
Starting my build today. Had purchased the SP120's as intake fans behind the HDD cages in my Corsair 550d case.
WELL The wires on SO short on these fans they don't even reach mobo if I go through HDD cage. Forget about using the wiring ports.
I expected way more for 35$ for 2 fans.
ASUS Z87-Pro - Intel 4770k
Corsair H80i
16GB Corsair Vengence Pro 1866
Corsair TX750w in a Corsair 550d
Old October 20, 2013, 06:00 PM
LOL seriously?
Cable length for fans I find is generally the same size from fan to fan. Most people are either using fan extensions or a fan controller of some form.
$35 for 2 fans is pretty cheap to be honest.
Old June 3, 2014, 06:10 PM
I agree with you.. I've bought 8 pcs of the SP120.. i might just buy an extra fan extensions if it won't reach my PWM cable splitter..
Old June 5, 2014, 12:08 PM
rjbarker's Avatar
Originally Posted by enaberif View Post
LOL seriously?
No kidding...I've got tons n tons of splitters and extensions kicking around..its part of the planning in your build, never "assume" the Fan Connectors will reach where you want them to go...personally I'm glad they keep them short vs long, let me customize the length instead of bundling all that extra cabling into a zip tie
And that is cheap, considering the Noctua NF Series and Alpha Cool E Loops are around $30 each
Firestrike Extreme: 21.452
MARK 11: 32.530
Old June 5, 2014, 01:43 PM
Alpha Cool/Phoyba eloops are closer to $20, no? It's the original's from Noiseblocker that are $30ish.
Wires not long enough? nwa4life Power Supplies 5 September 16, 2010 06:49 PM
Splicing fan wires - 3:1 TALON Water Cooling 7 September 6, 2009 03:32 PM
wires touching mobo? is this ok? thanks! go flames go New Builds 5 April 7, 2009 02:25 PM
messy wires cmac79 Guides & How-to's 27 October 9, 2008 07:38 PM
No Wires??????????????? Vinnie Case Mods, Worklog & Gallery 23 July 24, 2008 06:27 PM
