-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   fan controllers again... (http://www.hardwarecanucks.com/forum/air-cooling/63601-fan-controllers-again.html)
clshades October 14, 2013 12:35 AM
About 100 bux price range tops giver or take a little.
I'd like something that can turn off fans completely.
Something multi speed not just 2 or 3 speed settings.
Something reliable.
Something that can run up to 4 fans on one channel.
Not software controlled!
I almost bought that Aero with the USB3 ports... thank god I didn't.
KaptCrunch October 14, 2013 07:52 AM
Hydrostatic Fan Drives - USA
sswilson October 14, 2013 08:06 AM
How many fans / channels are you looking for?
clshades October 14, 2013 09:46 AM
6 fans on the 360 rad but I want to independently control each set. I'd like to shut off one set completely when idling.
1 front fan
1 exhaust
1 bottom fan
1 side panel fan 200mm
1 ram slot fan
I'm being cyber stalked... <--- googled. lol
sswilson October 14, 2013 10:28 AM
I was going to suggest looking into a scythe controller, but quick checks at both ncix and newegg show zero stock... did they go out of business, or maybe got out of the Canadian market?
edit:
Scythe"KAMA PANEL"
Looks like maybe no Canadian market.......
edit#2
Scythe USA-Where to Buy
Maybe just a lull in supply?
edit3: That's just weird... there don't appear to be any scythe fan controllers available in Canada.... did they lose their CSA rating?
KaptCrunch October 14, 2013 11:18 AM
1 front fan
1 exhaust
1 bottom fan
1 ram slot fan
Do the math of total amp/watts on channel, 3 or 6 gangs of fans max ?
so its six channels/knobs looking 4
rjbarker October 14, 2013 11:33 AM
Lamptron FC9....check NCIX..no frills...no software...smooth voltage control of fans and 50W per channel / 4 Chanels.
KaptCrunch October 14, 2013 11:47 AM
FC9 - Lamptron
SPECIFICATIONS:
Dimension:148.5mm*42.5mm*75mm(5.25″ Bay)
Power Output:Up to 50 watts per channel
Control Channel:4 Channels
LED Color Available:White, Blue, Green, Cyan, Red, Purple, Yellow
Panel Color Available:Black Anodized/Silver
DC Input:3 X +12v (Standard 4 Pin Molex)<------------note takes 3 plugs to power it
DC Output:0V- 12V DC
Fan Connectors:4 X 3-pin connectors
Recommend PSU wattage: 600w or higher
NSdeadly1 October 14, 2013 04:05 PM
edit:
Scythe"KAMA PANEL"
edit#2
I'm pretty sure I read somewhere that Scythe isn't shipping it's full line to North America any more. Can't remember where I saw that though. Go with Lamptron, mine has been flawless.
clshades October 14, 2013 07:47 PM
do the lamptron switches go to off? Sorta makes or breaks the whole thing for me. all the way low isn't good enough it needs to go off :)
