Old July 10, 2013, 06:58 PM
r0k0's Avatar
Default Fans and Controller question
been looking for fans for WC setup, been on NCIX and FrozenCPU
looking at the Koolance fan
Koolance FAN-12025HBK 120X25MM 108CFM Dual BALL-BEARING 3 Pin 12VDC 2600RPM 32.80DBA
says 5.4mm/h20 static pressure... which is almost 70% more than the Corsair AP120 High Performance...
are these info true or not ? because I was gonna go for Corsair until I saw these haha
also for a Controller... I need to power 6 fans and found some controllers I like, which one would be the best by your opinion
Sunbeam 30W Rheosmart 6 Channel Smart Fan Controller - Black (PL-RS-6) - FrozenCPU.com
Lamptron High Wattage 6 Channel Rheobus - Black (FC-2) - FrozenCPU.com
Akasa FC.SIX 6 Channel Aluminum Fan Controller - 20W per Channel - Black (AK-FC-08BKV2) - FrozenCPU.com
Fractal Design Adjust 108 Six Channel Fan Controller (FD-FC-ADJ-108-BL) - FrozenCPU.com
FrozenCPU Dual Voltage 6 Port Baybus w/ Blue/Red LED - FrozenCPU.com
or on another note, buy a 1-2-3-4 fan controller and hook up this :
NZXT GRID Ten Port Fan Hub 3-PIN Matte Black
to make all the fans hooked up to it to go at the same desired speed ?
Thanks
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old July 10, 2013, 09:40 PM
KaptCrunch's Avatar
20.16 watts for 6 fans 3.36 watts for single and 5.4mm/h20 static pressure = 0.212598 inch less then 1/4" (Manometers) weak IMHO for a high FPI rad
with controliers don't excede watt rating of it be less then 80% of channel. room for cooling
Old July 11, 2013, 09:11 PM
r0k0's Avatar
which one would be the best ? because you lost me in those calculations.. lol
Question on this raid controller. lcdguy Storage 2 October 21, 2010 03:00 PM
Fan controller and PWM fans homer98 Air Cooling 4 September 28, 2010 07:51 AM
Fan Controller for Radiator Fans AmuseMe Water Cooling 13 May 17, 2010 07:10 AM
fan controller question... dmccaulley Cases 9 July 4, 2009 12:50 PM
Fan controller question + fans ADay2Long Air Cooling 1 May 21, 2009 04:20 PM
