Old June 20, 2013, 01:36 AM
Default AM3/FM2 heatsink - low'ish profile? (finally settled on a thermalright AXP-100)
I'm looking at upgrading my media center PC, mainly to do some mild casual gaming, nothing fancy really, just anything i can play for fun periodically with a 360 controller hooked up
the current specs are as follows
Asus M2N68-AM SE2
AMD Athlon X2 5050e (2.5ghz 45w)
Geforce GT210
4gb DDR
Antec Microfusion case
The case is what restricts my options being its low profile, which is great for an HTPC, it doesn't look out of place under my TV, so I have every intention of keeping it
my first though was to add a low profile radeon 7750 as they seem to be the best performing of the low profile graphics cards and run about 100$, nothing superb, but playable framerates should be achievable at 1366x768 resolution for whatever I would actually play using a controller
My other though, is getting a newer FM2 board and an A10-6700, not the 6800K for 2 reasons, the 6700 has lower tdp which i find more attractive for a small form factor, and the 3d performance is negligeable compared to the 6800k. both would be much faster than the current dual core in terms of cpu performance
the hiccup is, I'm looking for suggestions on an AM3/FM2 heatsink that will offer good cooling in a small form factor, low air flow, low noise, this is where im looking for suggestions
I really wish I could find a straight up 2U Heatsink with a couple heatpipes that I could form a shroud directly to the side fans for this, but so far no luck finding that
Old June 20, 2013, 05:37 AM
Varroa's Avatar
I use a Scythe shuriken low profile one with that same chip (5050e) and it works great. I am not sure if they make it anymore but it does a great job. The closest thing on the market now is one of the noctua low profile ones but they are much wider.
Shuriken Rev. B (SCSK-1100) | Scythe USA
Noctua NH-L9a AM2 AM3 FM1 FM2 Low Profile Heatsink Cooler w/ Slim NF-A9x14 92MM PWM Fan
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old June 21, 2013, 12:13 AM
I've been looking for the scythe big shuriken 2, I had one before but I sold it with my P5Q premium and c2q a couple months ago, wish I had kept it because they seem to be discontinued and out of stock everywhere now
that nocture nhl9 is a little too low profile for what i want, thought the nhl12 with a single fan may do the job and is definitely one i'm considering
i do have one of the amd dual heatpipe coolers somewhere, i suppose i could try it as it may yield pretty decent results.
Old June 21, 2013, 09:15 AM
lowfat's Avatar
Just an FYI, a lot of the cheaper FM2 boards don't include the stock AMD backplates. A lot of aftermarket cooling requires those backplates including all Noctua.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 21, 2013, 11:02 AM
that's not a problem, I've got a few backplates in the cabinet
I'm really just concerned on finding an HSF that will work to my satisfaction. There really aren't too many options for the low profile segment though it seems
Old July 12, 2013, 01:08 AM
I just found this guy, apparently its been announced recently, but can't find stock anywhere or any info on availability. It looks promising though
XIGMATEK - PRODUCT
Old July 18, 2013, 06:45 AM
Varroa's Avatar
Looks similar to mine.
Old July 19, 2013, 06:21 AM
Varroa's Avatar
This just went on sale at Newegg:
Newegg.ca - COOLER MASTER GeminII M4 RR-GMM4-16PK-R2 120mm Slim Fan Long Life Sleeve Bearing CPU Cooler Compatible with Intel 2011/1366/1155/1156/775 and AMD FM1/FM2/AM3+
Old August 15, 2013, 09:30 AM
I don't know how I didn't come across it before, since I'm sure I checked thermalright's website when I was on my search, or maybe I just searched newegg for thermalright coolers and didn't find any that fit the profile.
regardless, I stumbled on a review of the thermalright AXP-100 and the Scythe big shuriken 2 was in the comparison table quite conveniently and the the AXP-100 beat it by 5-6* or more so I went ahead and ordered one and now I'm not kicking myself for selling the big shuriken I had
anyway, previously with the AMD heatsink (heatpipe cooler from a Phenom II 955) with the cpu (A10-6800K) running at a max 3.2 I was seeing temps of about 36 idle, and 58 under load.
Now with the AXP-100 I'm seeing temps of 35 idle, and 55 at full load, BUT, I'm not limiting the speed to 3.2 anymore, it's free to roam all the way up to 4.1 as it pleases. So higher speed, slightly lower temp, and much much much less audible at full bore too
I call it a win
[WTB] Low profile 775 heatsink fan Sui Buy/Sell & Trade 1 December 1, 2012 09:59 PM
Thermaltake Launches Low-Profile CPU Cooler SlimX3 Ideal for Low Profile PCs and HTPCs FiXT Press Releases & Tech News 15 April 5, 2010 03:56 PM
Best low profile heatsink? Fudd Rucker Air Cooling 6 February 21, 2010 10:08 AM
low profile heatsink for LGA1366 Bones Air Cooling 20 March 7, 2009 10:51 PM
ThermalRight AXP-140 Low Profile Heatsink Eagle Eye Air Cooling 5 November 22, 2008 04:07 AM
