Old June 11, 2013, 11:14 AM
Alpine's Avatar
Default D14 without fans enough for a i7 2600k ?
Hello everyone.
Do you think that a Noctua D14 without fans will be able to cool down a i7 2600K ?
That cpu is only running 1 or 3 hrs at the time since i use it only for listening film.
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old June 12, 2013, 03:04 AM
Default d14
I wouldn't try it at stock volts. If you undervolt the 2600k it will likely be fine.
Though unless you need absolute 100% silence I would put a low rpm fan on it. Something near 500rpm would be nearly impossible to hear at a reasonable distance. Scythe makes some ultra-low rpm fans.
Old June 13, 2013, 09:26 AM
I would not recommend it either.
Get some low rpm fans - they will be quiet enough that you will not be able to hear them with a film playing.
Old June 13, 2013, 09:52 AM
Bond007's Avatar
In a decent airflow case yes, but if you want silence I think you would be better with low rpm flow case and cooler fans.
Replacing CM Evo fans with Noctua NFP12 Fans kr7777 Air Cooling 7 August 26, 2012 10:51 AM
[WTB] Z77 sabertooth, 2600k/2700k/3770k, fans, HD, quite a few things rommelrommel Buy/Sell & Trade 1 June 18, 2012 12:38 PM
Opinions on 3 fans vs 6 fans on a triple rad chrisk Water Cooling 5 September 24, 2011 08:20 AM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
