Old April 6, 2013, 08:27 PM
Default Cooler Master 690 II Advanced 140mm Fan
Hey guys,
Just a question, I have the Cooler Master 690 II Advanced case and it only comes with 1 140mm fan for the top for exhaust.
I was wondering if I get this for the second 140mm fan, would it be a good choice?
BitFenix BFF-SCF-14025KK-RP
Canada Computers | Cooling | BitFenix Spectre All Black 140mm Case Fan (BFF-SCF-14025KK-RP)
or how about these?:
Cougar Turbine 140mm Hyper Spin Bearing Fan 1000RPM 64.5/109.6CFM
Cougar Turbine 140mm Hyper Spin Bearing Fan 1000RPM 64.5/109.6CFM 17.9DB 3PIN Black - OEM
Also, is it better to have two of the same fan (remove the existing fan and get two BitFenix's?)? The Cooler Master fan I have is the Cooler Master A14025-10CB-3BN-F1 (1200 RPM).
Mainly if I am to get a new 140mm fan, it must be quiet but able to expel the heat out of my case. Due to the installation of the H70 CORE, the two Arctic Cooling fans made my rear exhaust to become a rear intake, the only exhaust now is the top.
Thanks,
deltatux
Old April 6, 2013, 09:09 PM
great_big_abyss's Avatar
The front fan (LED) is also 140mm too, FYI.
Old April 6, 2013, 09:18 PM
Yes, that's correct, but I'm only talking about the top fan(s) as that's where my interest is in replacing. I see no need to replace the front fan as it's doing its job.
deltatux
Cooler Master Advanced 690 II pricecheck terrybear Price Check 0 September 27, 2012 03:52 AM
[FS] Cooler Master 140MM Blue LED Fan x2 - SOLD! Flemminr Buy/Sell & Trade 0 July 28, 2012 06:59 AM
Cooler Master Announces HAF 932 Advanced FiXT Press Releases & Tech News 16 April 11, 2011 09:26 AM
Cooler Master 690 II Advanced ReD PainT... blueweb Case Mods, Worklog & Gallery 15 July 4, 2010 12:41 AM
Cooler master 140mm fan JBM12G Air Cooling 3 June 19, 2010 08:09 AM
