  #21 (permalink)
Old August 18, 2013, 03:39 PM
Your_friendly_gamer's Avatar
Originally Posted by BrainEater View Post
Cheers !
That's exactly how I learned that lesson the first time. The second time I learned it was when AS5 shorted a mobo out.....At that point I did my own tests , and a whooooole buncha reading.
You CAN use cheese.Or peanut butter.Both contain oil which is an effective TIM.
Here's the secret about T.I.M. for computers ;It's basically all hype !
There are 10,000x more commercial electronic components with higher heat density than CPU's , and none of them use anything more than commercial heat paste like the MG stuff.There is a reason for that.
Hi Baineater,
I am going to go buy it tomorrow or day after, as there are about 3 stores in Ottawa that carry it. I am trying to read about it more, is non electric conuctive?
  #22 (permalink)
Old August 23, 2013, 12:15 PM
I just gave away a once used Gelid Extreme thermal paste not even thinking that it was the only paste I had. I wasn't happy for about 10 minutes considering it did nearly the best in the whole test. Oh well. Time to buy something cheap now. lol
Thermal Compound Kieli New Builds 8 December 24, 2010 10:48 PM
Thermal Compound homer98 Water Cooling 10 March 9, 2010 06:52 AM
best thermal compound now? BobbyLou Air Cooling 9 December 27, 2009 11:20 AM
How much thermal compound? 4DoorGTZ Overclocking, Tweaking and Benchmarking 16 April 2, 2009 07:15 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 06:17 PM
