Old March 22, 2013, 05:42 PM
Dr_BenD_over's Avatar
Fallen Folder
Default Ultratrosonic cleaning of a heatpipe HS?
Has anyone done this... My old TRUE is looking like crap and needs some TLC.
All's well that's Haswell
Old March 22, 2013, 10:21 PM
KaptCrunch's Avatar
what you want to clean ? pipes, mating surface, cooling fins
Old March 23, 2013, 12:44 AM
IRQ Conflict's Avatar
Ultra sound will indeed clean it. But I don't think it would polish it. Your looking to bring the bright back aren't you? Good old fashioned elbow grease for that methinks.
Old March 23, 2013, 01:06 AM
dustin1706's Avatar
Yeah if the fins are all full of junk, ultrasonic in a mild soapy solution or solvent will clean it out nicely. If you are looking for a cleaning/polishing, then you would want to go with a vibrator/tumbler with a relatively soft media. Would have to find one large enough to fit the heatsink though.
If you want to do it on the cheap, I've used mothers mag polish and dollar store pipecleaners with great effect. The pipecleaners even let you get between the fins.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old March 23, 2013, 08:55 AM
Fallen Folder
There's dust on the inner fins that just won't come off with air, probably from this lovely damp climate and all the crap in the air from the local polluters and the top is pretty gunky, probably from oily fingerprints that have attracted all sorts of crap.
Old March 23, 2013, 09:33 AM
Perineum's Avatar
Fill a bowl with hot tap water and a bit of dish soap.... soak it upside down in there for an hour and then just rinse it off in hot tap water. Should look like new again.
I've done this with no issue.
Cutting the top heatpipe of an AC7PRO m0pelley99 Air Cooling 11 January 31, 2011 05:52 PM
[WTB] Heatpipe assy for Rampage II Extreme turtletrax Buy/Sell & Trade 2 October 15, 2010 11:21 PM
Heatpipe dilemma Logger Air Cooling 9 November 16, 2009 07:54 PM
Thermalright or Noctua Heatpipe Cooler? Rocco_360 New Builds 1 March 19, 2009 01:02 PM
